Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
harmonic balancer install tool?
Old Nov 24, 2009 | 10:53 AM
m6z's Avatar
m6z
Default harmonic balancer install tool?
Where can I buy a balancer install tool? The guy here on tech seems to no longer be making them.
What are my other options?
Old Nov 27, 2009 | 06:13 PM
LS1BLKSS's Avatar
Banned Village Idiot
autozone if you have one in your area, you can rent it
Old Dec 4, 2009 | 06:57 PM
Chevellecamino69's Avatar
do u use it to remove it to or only install ima buy an slo balancer
Old Dec 4, 2009 | 07:25 PM
Camaroholic's Avatar
You can find a local industrial nut and bolt place and buy some metric threaded rod, a couple of nuts, and a couple of large washers. I bought 3' of threaded rod, nuts and washers, for something like $20 a few years ago. I cut off about 8", used a spare piece of pipe I had laying around (about 4" long), and voila... Harmonic Dampener Installation Tool. Use the same tool to install the crank gear for the timing set.
I also cut off about 6" of the rod and use it when removing the balancer and crank gear (use it for the center of the puller to push against).
I don't recall the bolt size/pitch for the crank, but it's probably around here somewhere.
Old Dec 5, 2009 | 11:31 PM
thirdgenbum's Avatar
m16x2.0 if i remember correctly
