Welding rocker bolt hole shut and re tap?
My sister is in school and she bought my old DD 2003 grand prix 3.1 pos. I have put 1 engine and 2 heads on this thing. It keeps pulling the rocker bolt threads out of the head ive tried helicoils like GM told me to. It was a 6 month fix each time thats it. I have a tig welder at my disposal. Can i get crafty?? This is a 3 grand car im not too worried about it. Hell if i could i would weld the steel stud to the aluminum head but that wont work. I want this thing out of my garage so any help will be greatly appreciated. Oh and so you dont ask all the rocker arm bolts are torqued to gm new spec. Also the push rods are the correct lengh.
The 1st engine was replaced by gm under warrenty for this problem. Im on the second set of heads on the second engine. All the gm techs i talk too say say that its a crappy casting. I needed space in the garage so i put the thing back together with one less rocker arm and one injector unpluged. A compression test revealed 2 cylinders low on compression. Time to remove the engine and find a donor. I wonder how long it will last. It seems to drive fine with a slight hesitation.
