Welding vband without warp?
Good job on the welding. Is there any reason why you just didn't make your own merge pipe out of stainless rather than buying the carbon steel Flowmaster?
If I ever redo it, which is likely to happen, I might try to re-visit my dual idea, and if not, Ill probably rebuild the y-pipe with all stainless.
J.
Just running a bunch of tacks around it is a bad idea, typically that will result in inclusions in the weld that will end up being a location for cracks to start. The best way of dealing with this is to tack it every inch or 2 around the flange, and then go back and run short beads connecting the tacks in a pattern that skips around like you would tightening lug nuts.
308/308L filler is intended for welding stainless like 304. 309/309L is recommended for welding dissimilar metals, like welding mild to 304 or 409 stainless.
And finally, yes, newer inverter welders are more easy to control at lower power settings, but you can pretty much do it with any TIG welder as long as you can find a small enough tungsten.
Ive alway welded, when it comes to comtroling the heat, tack evenly around to hold it, and then small beads connected on opposite sends, making sure to backweld a touch to clean up on the tacks. wish i could afford a tig machine, id be welding the crap out of stuff right now lol
Beaudacious
beaudacious
Sorry if this is a stupid question. I am new to welding. I will be spreading out the welds as mentioned in this thread will clamp the flanges together when welding. Thanks!
