Good beginning welder
they also are coming out with a 185amp model if they haven't already so I guess people can get into a little thicker aluminum.
Stuff just takes so much heat its ridiculous.
Ive got 5 welders all miller, some are pushing 25+yrs old - but the new technology welds much smoother.
I'm going to answer your question here very easily. Don't be shocked at the price because trust me, you are getting a lot more than you paid for with this Miller. I weld SS tube all day for a living and my tungsten will never touch a torch that doesn't plug into a blue machine. This machine is aimed right at the hobbyist/enthusiast market and will do your Aluminum oil pans just as long as its not too thick
http://store.cyberweld.com/mitigwedi165.html
Only things I believe you will need after this is a bottle of argon and a dual regulator setup to back purge.
you will almost ALWAYS get what you pay for with a welder. i'm not saying "don't buy the harbor freight welder," but it is what i'm thinking. before you do, search around on craigslist or go to some home/farm supply stores and see what else is out there. look for something more like a Hobart, Miller, or something else besides a harbor freight welder.
Put one side by side with even the 140 class from the big 3 makers and the difference in quality is obvious, much less when you weld with them.
They are cheap crap. If you want to do light duty car stuff, where a frame or bracket is the heaviest you'll do get a good 140 class Miller/Hobart/Lincoln with a gas bottle and be happy.
If you want stainless/Al upgrade to at least the 180/210 level model with spoolgun capability. Next step would be a TIG setup as mentioned earlier in the thread.
