can a broken starter motor boss mount be welded back on with engine in car.....
I'm gonna have a welder weld the piece that broke off..back on. Then get a threaded rod with nuts/washers on each end, instead of rethreading the mount with a tap. Just afraid whern tightening it using the factory bolt it'll push the welded piece apart and break it off again.
We'll see tomorrow hopefully.
Yeah ignore what I said I thought you meant the part of the starter broke, then I read on how the block bosses always crack when the one bolt gets loose and the torque of the starter twists and breaks off a chunk. Or maybe your starter did break too but either way I just got a ebay starter for like $65 too, prob the same place u got it from. If so I was very impressed with it, NEW not reman and even included a huge long sheet of electronic specs of crap (ripple voltage?, etc) I dont know what means but shows they tested the motor and surprised since it was so cheap. I didnt know about the 2 longer bolt thing until it was put in so I figured it was a cheap knockoff and was to cheap to make it like the stock design but found out this way is better. Its being held in with only 1 long bolt for now, got to pick up another long bolt somewhere, I assume I can just get a copy of the other original long bolt?
And yes, my problem started when the starter housing at the shorter bolt broke, then it broke the mount of the longer bolt. Im gonna get that piece welded back on though so I can use both long bolts.
i have the exact same problem. what all did u have to remove for him to get it done? i just ordered new updated starter off ebay. maybe i can get luck to have someone come to my house and do it. might have to bring it to them though... any reccomendations on how to get job done?
