Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Rear crank seal installer
Old Feb 25, 2010 | 05:41 AM
02_camaroz28's Avatar
Default Rear crank seal installer
I'm looking for one of the crank seal installers but im not having any luck. If someone knows where I can order one online and has a link that would be great. Thanks!
Old Feb 25, 2010 | 07:30 AM
RARON455's Avatar
FYI from what I see of it in my service manual,,,, It is gonna be expensive unless you are a GM service mechanic, it will probably be a 1 time use tool, the tool is a J-41479 in my service manual though, I am sure the stealership can get it for you. I just use a drift-punch and a block of wood and walk the seal into the cover myself.
Hope this helps
Old Feb 26, 2010 | 01:32 AM
G-Body's Avatar
sawzall wielding director
Use a PVC pipe cap. I forget if it was here or on performance trucks that I read that, but it worked great. IIRC it is a 3" PVC pipe plug like this and it fit perfectly
Old Feb 26, 2010 | 02:16 AM
Hey thanks for the reply. I know this might be a stupid question but how exactly do i use this. Do i just put the seal on the end of it and tap it in until it is sitting all the way down against the rear cover? I have also heard there are a couple different seals you can get. Do you know the difference? This is the one Im going to order. http://speed-eng.com/store/lsx-rear-...l-p-10873.html This is my first time installing a rear seal on an LS motor so Im just covering all the bases so I dont screw it up. Thanks!
Old Feb 26, 2010 | 03:48 PM
ccsanders01's Avatar
also i just read that you should put thread sealer on flywheel bolts, some people replace the seal while the bolts may be where the oil leaks from
Old Feb 26, 2010 | 07:49 PM
bigj2717's Avatar
Usually the difference in the material. I know for the lt1 they make a rubber one and a teflon one. For the flywheel bolts put locktight on them and torque them to spec in a star pattern
Old Feb 26, 2010 | 08:30 PM
Thanks for the replys.
Old Feb 26, 2010 | 11:27 PM
G-Body's Avatar
Yep, I just centered the cover around the crank (doesn`t apply if you are replacing the seal and leaving the cover on the motor). I put the seal over the crank and up against the back cover, put the pipe cap on the back and tapped the back of the pipe cap with a hammer until the seal slid all the way in.
