Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Any experience with Floor lifts?
Old Mar 8, 2010 | 10:35 PM
sapper_daddy's Avatar
Question Any experience with Floor lifts?
Hey if you own a floor lift or are thinking about buying one, what are your opinions, comparisons, general thoughts as far as:
does it fit your garage carport well?
build quality?
safety features?
ease of use?
Guess what I'm getting at more or less is, what did you like and was it what you thought it was going to be? I'm shopping, trying to find something nice, usable, I can pull engine and trans from underneath...etc.
Right now I'm a little at a cross roads with what type to buy as well, 4 post for the easy setup and better looks/use in an everyday carport, or the 2 post b/c of the ability to do suspension work as well.....
what are some ways that suspension chassis work can be done on a four poster? put a jack across the width of the lift?
Old Mar 19, 2010 | 12:13 AM
no response? I'm just looking for a lift for personal use....checked out superlifts, really expensive, but i like the idea of the jack bridge that makes suspension work possible, which they have as a package deal. Any thoughts?
Old Mar 19, 2010 | 03:14 PM
6spdgto's Avatar
I have a four post that I use on a regular basis. I purchased "rolling jacks" that go between the runways so that you can lift the car off of the runways for suspension work and then lower it back onto the runways for final tightening the proper way.
Old Mar 19, 2010 | 10:25 PM
Magic Man's Avatar
Where did you get the jacks without spending an arm and a leg?I have wanted them but to much green. Thanks
Old Mar 20, 2010 | 08:53 AM
6spdgto's Avatar
Greg Smith Equipment They are still about $600 but worth every penny if you need them.
Old Mar 20, 2010 | 01:17 PM
Magic Man's Avatar
Thanks for the info.I think the Direct Lift Pro Jack 3500 is what I will get.Thanks again.
Old Mar 21, 2010 | 02:59 AM
35th SS's Avatar
benwil 2post lift here.bought it used for 1400 bux installed and spend another 1800 to wire it up to the house current.made in the usa.not those other ones that are made in china.
Old Apr 18, 2010 | 02:36 AM
Silverback's Avatar
I know that things are expensive in HI, but $1800 to wire it? And $1400 _installed_, isn't half of installing it wiring it?
Old Apr 18, 2010 | 03:35 AM
35th SS's Avatar
no they only install the lift and I had to hire a liget elec. to wire it to house current.
Old Apr 22, 2010 | 03:33 PM
kickassT/A's Avatar
i had inground lifts at the dealer when they upgraded my bays for the H1 hummers. They suck, lol. if all you do is trucks they are fine, but the lift arms are too tall and the ramps to go over the arm pads drag even on stock cars. a good 2 post would be my suggestion, especially with the ground in louisiana. even in houston our dyno pit would get enough water in it to throw a rooster tail every once and awhile, lol
Old Apr 28, 2010 | 03:00 AM
davidws6's Avatar
Default 2 post lifts
I have a two post Naussbaum up at my house in Kansas. It's ok, though it has the overhead beam with the Equalizer cables. In 2 years with moderate use, no problems.
Here in Jax. FL. I found a 2 post Mohawk System 1 9,000 lb. Only thing between the towers is a hydraulic line and a clear floor. It's also built like a tank ! Will fit under a 10ft ceiling but you really need 12ft if you want to lift a pick up.
I installed one of these in a shop years ago in Kansas and it worked flawlessly.
Mohawk's are a little pricey, but get what you pay for .
Can't wait to get it installed at the house I'm buying for a cam change and stage 2 port on the heads
Check out Craigslist in your area. That's where I found both of mine.
Doing suspension work on a 4 poster? You'll need some sort of jacks between the runways. Negative about that is you won't be able to drop any engines out the bottom !
Old Apr 28, 2010 | 11:31 AM
venom346's Avatar
Default .
Heres our lift and cars on it. It's a mid rise scissor type lift. @$1K starting.
Old May 1, 2010 | 10:10 PM
SScam68's Avatar
is it fastened to the floor?
what does it take to power it?
Old May 2, 2010 | 07:57 PM
venom346's Avatar
No it has rear wheels, the thing weight about....900-1100 LBs. the hydraulic station, has a lift point to where it doubles as a rolling jack for it.. my fav, feature is that you car park over it and it goes un-noticed.
Its powered off 110v house current. a gallon of self contained hydraulic fluid and thats about it.
Old May 2, 2010 | 08:25 PM
35th SS's Avatar
nice setup.and stays hidden when the doors is close.
Old May 2, 2010 | 10:39 PM
venom346's Avatar
Exactly, Plus If i move, I just drag it onto a trailer and move.. nothing permanent.
Its good for front and rear suspension work. The only issue I would have is Trans removal for an F body as th ecenter brace of the lift gets in the way. but I love it.
Old May 3, 2010 | 12:34 AM
35th SS's Avatar
ya seen that as your only disadvantage.perfect for indoor use.I gotta get a roof over mine down the road.I can almost do everything with this benwil.trans.jack and plasma cutter is next and Im set.still debating to go cheap or the high $$ ones.
Old May 3, 2010 | 08:30 AM
venom346's Avatar
I'd Looooove to have a plasma cutter.
That and a better welder and im set.
Old May 3, 2010 | 11:13 PM
35th SS's Avatar
I hear ya.looking at the thermal dynamics cutmaster true series 39 calling my name.
