Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
ls1 specific tools
Old Jan 4, 2004 | 09:16 PM
NRC-Motorsports's Avatar
Default ls1 specific tools
i remember an article a while ago in gm hi tech mag ,that gave alist of ls1 specific tools for building ls1 engines , anyone know of ls1 specific tools and there make/# thnx bob
Old Jan 4, 2004 | 11:22 PM
Gen3Benz's Avatar
kent moore makes a whole ls1 kit, every special tool for the ls1
they also make a time-sert kit for the whole engine
Old Jan 5, 2004 | 06:58 AM
Default tools
thank ,what is a time-sert kit bob
Old Jan 5, 2004 | 07:52 AM
Reckless's Avatar
Super Moderator
Nothing real special for just building engines Bob. The usual stuff. Some people prefer to use the GM designed tool though. Definitely get a brass hammer (for removing main caps - they get stubborn and the brass will not damage them)
Old Jan 5, 2004 | 08:52 AM
Brains's Avatar
So far I've been able to persuade the main caps out with ease, just a little "encouragement" from a handy object here and there. Most of 'em come out easily if you stick your fingers in the windows and lift up evenly.
I'm about to rig up a crank spinning jig on the bench and a ghetto journal polisher to remove a touch of surface poop from a crank that sat in some water :puke: At least it hasn't pitted it yet, so it's quite usable without needing to be cut .010"
Old Jan 5, 2004 | 06:36 PM
Gen3Benz's Avatar
the kit comes with drill bits and taps for every hole on the block.
when you pull/strip a thread on aluminum you have to drill bigger, tap, and screw in a time-sert. time serts are like screw-in threads that you lock-tite in place.
Old Jan 5, 2004 | 06:58 PM
oh ok its a heli coil set for these engines thnx bob
Old Jan 5, 2004 | 09:39 PM
Gen3Benz's Avatar
not helicoils, they are hardened steel inserts not slinkee-like inserts
Old Jan 6, 2004 | 11:12 AM
mojols1's Avatar
helicoils are hardened stainless steel that work fine-have used them to hold exhaust manifolds with no problems
Old Jan 6, 2004 | 08:17 PM
Gen3Benz's Avatar
exhaust manifolds ok....try bolting a head down with one. good luck
time serts are solid metal
