Shopping for a Torque Wrench ???
I don't see much of a point in getting the 3/8" one, it will not have enough capacity for lug nuts, some head bolts or just about any larger bolt, and you'll want something more sensitive to set a lot of bearing preloads, like a 1/4" one.
Honestly, for what most people use a torque wrench for just get a cheap 1/2" clicker and learn how to use it correctly. Even a fairly inaccurate one will still be more accurate than most people's technique, and then if you find that you need a special wrench for a specific application (like if you get into rebuilding rear axles), then get a beam one specific for that.
Finally, never leave a torque wrench set, always loosen the adjustment till you take the tension off the internal assembly, it will stay accurate for longer.
The real issue is repeatability, since in most cases, you're using a torque wrench to get things tightened evenly and being even 10 or 20% off in actual value doesn't really matter, which is a good thing because I only know of a few people that regularly get theirs calibrated.
That said, a buddy of mine got access to a calibration setup and we collected a bunch of torque wrenches (he had a old click snapon and a newer didgital one, and a matco, we also came up with a dozen more ranging from a few super cheap HF ones to assorted vintages of craftsman ones, I had a few IBM issue ones that were originally used to service their tape robots).
We found all the digital ones were not repeatable, and the 2 snap on ones we couldn't even get calibrated accurately. The only commonly available ones that were repeatable and accurate were the cheap HF ones (and obviously, a craftsman beam type). Otherwise, the IBM ones were really good (I keep forgetting the brand name, but they're custom made for IBM, they have an IBM logo on the box) and a maybe 30y/o snapon and maybe a 25y/o craftsman were at the top of the list.
That being the case, I swear by my
http://www.harborfreight.com/1-2-hal...rench-239.html
they're usually on sale for $9, and we didn't find one out of 4 that were more than 3% off or showed more than 2% variability WRT to repeatability. None of the more common big names were even 2x that
I'm pretty sure that a lot of the cheap ones are the same wrench being sold under a different name, I haven't confirmed it but they all look identical, come in identical cases...
've been using one in my car for wheels for over 3 years and never had a problem. My only recommendation would be to check them against a known wrench to verify the torque settings are close because a friend had one that was WAY off but he returned it for a replacement and the replacement was fine.
Lets face it, how many genuinely useful tools can you buy for $9 anyway?
You can get some real junk at HF, but if you shop around there are some real jems also. I think HD, lowes and Sears have figured it out also, and occasionally you can do better getting stuff from them. Secondly, before you start bitching about Chinese and Indian made stuff... HF is actually an American company and is notably the only place where you can get American or mostly American made products in some categories (like for example, their US General line of compressors is _the only_ major line of smaller than industrial compressors that is mostly American made, the tanks are made in VA, the motors are nice Baldor or AO Smith motors (go look at the junk that comes on a IR or CH compressor right now), with Square D and similar electrical parts, all assembled in I think it's South Carolina. The only thing on them that is not US made is the compressor head, they're from Italy)
however I did'nt use a TW on the timing cover, water pump, oil pan and intake bolts wrench was way to big, so I used the cross pattern snug down then add a little more technik is this OK?
are you guy's using a 1/4" TW on these bolts?
what happens if you over torque? will it stress the bolt then snap the bolt?
when I get around to a head swap I probably get a nice 3/8" TW and referr back to this an like threads for expert advice.
Thanks
