Shopping for a Torque Wrench ???
however I did'nt use a TW on the timing cover, water pump, oil pan and intake bolts wrench was way to big, so I used the cross pattern snug down then add a little more technik is this OK?
are you guy's using a 1/4" TW on these bolts?
what happens if you over torque? will it stress the bolt then snap the bolt?
when I get around to a head swap I probably get a nice 3/8" TW and referr back to this an like threads for expert advice.
Thanks
Also keep in mind that some fasteners are torque-to-yield (such as some OEM cylinder head or flywheel bolts); these should only be used once - once they have been torqued, they will no longer produce the required clamping load if re-torqued.
I'm sure this only scratches the surface (so to speak). It is a very expansive subject.
UPDATE:
Found a Gearwrench 25-250 in/lb torque wrench that's made in US and A. Ordered that, along with a 20-100 ft/lb Precision Instruments split-beam style torque wrench from tooltopia.
