aluminum heads + chain = ?
anyway, even with an aluminum head motor it should be fine , but i would prefer to lift from the block, and lift from the heads as a last resort
do not buy a plate. just make your own. take off the valley cover and make a steel copy of it with a nice hook
also, when you put the bolts in, bottom them out in the hole, then back them off a turn or two, you want to make sure its pulling up on the hole itself and not pushing into the bottom of the hole, thats how you get cracks inside you cant see untill its too late.
