Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Hawk LS Series Harmonic Balancer Installation Tool & Other Stuff
Old 01-05-2016, 12:09 PM
NJnative's Avatar
Just ordered mine and can't wait for it to arrive to do this cam swap! Great customer service too, very quick responses!
Thanks, CoSPEED
Old 02-17-2017, 07:10 PM
TipsyMcStagger's Avatar
Originally Posted by Burken01
(1) You thread it into the crank until it stops
(2) Install your harmonic balancer
(3) Then add the washer/spacer and end nut
(4) Tighten the nut down and it will start to push the balancer on
This is the correct way to do it vs using an old bolt to pull the balancer on
BUMP - Question for clarification;
After following the above steps, should the old pulley bolt still be used to fully seat the pulley? In other words, after following the above procedure should you then -
(1) remove the installation tool
(2) insert the old pulley bolt and tighten to 250 ft/lbs
(3) remove the old pulley bolt and insert new pulley bolt
(4) tighten new pulley bolt to 37 ft/lbs, then turn an additional 140 degrees
Tipsy
Quick Reply: Hawk LS Series Harmonic Balancer Installation Tool & Other Stuff
