Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Hawk LS Series Harmonic Balancer Installation Tool & Other Stuff
Old Jan 13, 2011 | 11:01 PM
COSPEED's Avatar
Default Hawk LS Series Harmonic Balancer Installation Tool & Other Stuff
Here is the Hawk LS Series Harmonic Balancer Installation Tool. It has been on market for 8 years now and proven itself to be a must when installing a harmonic balancer. Universal installer tool kits do not work well with the GM LS Series motors. No longer do you have to chance stripped or damaged crank threads trying other installation methods.
There are two versions offered, the GM LS1, LS6, LS2 & LS3 or the GM LS7. The GM LS7 version is approximately 3 inches longer due to the deeper crank threads in the GM LS7. So the tool needs to be longer. The GM LS7 version can be used on other LS motors but there may be clearance issues with the added length of the tool during use.
HOW TO ORDER? PLACE YOUR ORDER
HERE FOR GM LS1, LS6, LS2 & LS3
HERE FOR GM LS7
COMP Cams Camshaft Degree Kit (GM Gen III/IV LS-Type Kit)
This kit contains everything needed for camshaft degreeing when the cylinder heads are OFF of the engine.
Kit includes the following:
• #4790 − 9" Degree Wheel
• #4901 − Heads Off Degreeing Fixture
• #4909 − 0-1" Travel Dial Indicator
• #4912 − 5" Dial Indicator Extension
• #4933 − Plate Style TDC Stopv
• #4794 − Wire Degree Wheel Pointer
• One Crankshaft Socket
COMP Cams LS Valve Spring Compressor
Exclusive new valve spring removal tool engineered specifically to work with all GM Gen III/IV LS-type engines. The easy-to-use custom design enables the removal of one or two valve springs at a time without the hassle of removing the rocker stand or any of the other installed rockers. The tool works both with cylinder heads installed on an engine in a vehicle or with the cylinder heads off. The simple design facilitates easy usage in vehicles where other tools are incapable of reaching the tight spaces. This tool is a “must have” for all LS engine builders and enthusiasts.
If you have any questions, please do e-mail us or call us as we may not be readily available on LS1TECH to answer questions you may post here. Note that order update requests are not answered here, please e-mail or call us direct.
PLEASE LIKE OUR facebook PAGE TO KEEP UP ON NEW PERFORMANCE PARTS ANNOUNCEMENTS AND SALES
BUY, SELL & TRADE PARTS HERE
LSX PARTS BUY SELL TRADE
F-BODY PARTS BUY SELL TRADE
LSX & LTX TECH SUPPORT HERE
LSX TECH SUPPORT
LTX TECH SUPPORT
LSX | LTX TUNING TECH SUPPORT
www.COLORADOSPEED.com
E-mail | facebook | driveCAMARO | driveCORVETTE
Old Jan 15, 2011 | 12:59 AM
01ssreda4's Avatar
+1 for Hawks.
Old Jan 15, 2011 | 01:32 PM
Damian's Avatar
LSX Mechanic
I bought 2 of these back when they first hit the internet. A must-have for A4 cars.
Friendly tip. Oil the threads before every use. It makes them last longer.
Old Jan 15, 2011 | 07:30 PM
01ssreda4's Avatar
Please tell me why it would matter on the trans type
Old Jan 15, 2011 | 08:51 PM
618HAWK's Avatar
There seems to be a bit of confusion why there are two versions.
There are two versions offered, LS1, or LS7 note the LS7 version is approximately 3 inches longer due to the deeper crank threads in the LS7. So the tool needs to be longer.
*The LS7 version can be used on a LS1 but there may be clearance issues with the added length of the tool during use.
*The price difference between the version’s is due to the add cost of material and method of shipping. This is why a LS1 version is offered at a much lower cost.
Old Jan 15, 2011 | 08:59 PM
Damian's Avatar
LSX Mechanic
Because M6's can be put in 4th, thread the stock bolt in, TQ pulley, install new bolt. Done. No install tool required
I never use this tool on manual cars. Only automatics.
Old Jan 18, 2011 | 10:54 PM
01ssreda4's Avatar
Ah I gotcha, I use mine on M6s and A4s (I have the only A4 F-body I have ever worked on ) Still doesnt change the fact that I do not want to pull the pulley on by a spinning bolt. And that is the reason I have the tool. I have a Kent Moore flywheel holding tool for keeping the motor still
Old Jan 18, 2011 | 11:27 PM
BlueBird346's Avatar
Im definitely going to buy one soon.
Old Jan 26, 2011 | 08:43 PM
Paul 75 L82's Avatar
I got to use the tool last week end putting the balancer on my LS6 and it worked fanstatic. Just thought it was great I'm so glad it bought it. I've read some terrible stories about installing the balancer but the Hawk tool makes it so easy.
Old Jan 26, 2011 | 10:40 PM
618HAWK's Avatar
Thank You for the kind words!
Old Nov 4, 2011 | 03:14 PM
3rdCoastPowerSports's Avatar
This is a must have tool and is made with with excellent professional quality... AWESOME tool and at a great price especially for how well it is constructed. If you don't have one hit up BYUNSPEED and buy yours.... Thanks 618HAWK and BYUNSPEED
Old Nov 6, 2011 | 01:26 AM
01ssreda4's Avatar
Hawk for president
Old Mar 29, 2012 | 05:05 PM
2baditsnotachev's Avatar
Just got my balancer installer today. Worked great, good product.
Old Apr 3, 2012 | 01:56 PM
the_reaper's Avatar
Just ordered mine, This is my first ls build and am trying to complete the shortblock myself
Old May 16, 2012 | 09:33 AM
AMS13's Avatar
when ever I try to click the link to check out the price of the balancer, I get a 403 forbidden page...
Old Oct 11, 2012 | 12:18 PM
wetcoast's Avatar
I tried to checkout on the Colorado Speed website and it keeps asking me to change the ship to address. I'm in Vancouver, BC Canada if that makes any difference.
Old Oct 11, 2012 | 02:58 PM
BOXCHEV's Avatar
What a jackass.
I was also waiting for the motor to slide off that block of wood as he was hitting it so he could bust up the cast oil pan.
Old Oct 19, 2012 | 12:01 PM
COSPEED's Avatar
FYI, there will be a 1-2 day delay on shipping the balancer tools. We'll get caught up soon. Thanks.
Old Mar 19, 2015 | 04:24 PM
mightyquickz28's Avatar
Thanks for offering this tool. I was amazed how few good quality installation tools were available for this important task. I'm glad I read up on various peoples horror stories of using the generic/rentals from Autozone, etc. In stark contrast, everyone that has the Hawks tool can't seem to praise it enough. I ordered mine a couple of days ago to install my new ATI super damper on the turbo 5.3. Should be here tomorrow!
Old Mar 23, 2015 | 01:49 PM
Ordered this tool after finding it advertised in Group Purchase (by CoSpeed, Which I missed out on). I looked up the website and ordered it online on 3/17/2015 and got it (Shipped from California to my state of NY) on 3/21/2015.
Got the components
Here's the tool a bit closer up
Installed!
It was just like everyone else that bought the tool mentioned. Easy as could be. I put some ARP bolt lube on the installation tools threads and threaded it into the crank by itself, to make sure the crank threads would be lubricated. Then unthreaded the tool, put the ATI Super Damper 917302 (non-underdriven/stock diameter) on the crank snout, then fully threaded in the installation tool. Once that was as far in as it could go, I used my open end wrench to tighten the 'driver' and it pushed the hub on completely without a hitch. Lubed the ARP 12 point crank bolt, put some high temp Silicone on both sides of the ARP washer (otherwise, oil can seep past the keyway provided on the ATI hub), and torqued it to 230ftlbs
I highly recommend this tool!
Thanks,
David K. Wilson
