Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Rusting Tools
Old Jan 31, 2011 | 04:07 PM
krissoto's Avatar
Default Rusting Tools
I don't have the most expensive tools out there, but I do take pride and care of what I have, I have some sockets and other little things that are starting to get minor surface rust. I don't keep any of my tools covered in oil or grease or anything, but what can I do to help stop the rusting. I know if I used them more, but I have quite a few of the same tools, so I kinda have certain ones I use all the time. Any tips or tricks you guys can throw my way that might help.
Old Jan 31, 2011 | 05:37 PM
MeentSS02's Avatar
Kleeborp the Moderator™
People use vinegar to remove the rust (you'll need to leave it soaking for a while), and I like Fluid Film to keep it at bay.
Old Jan 31, 2011 | 06:57 PM
t/a98's Avatar
Fine steel wool and machine oil. Once rust starts though the only cure is to Sand down to bare metal and recoat. Second best thing is to nock the rust down and use oil to keep it from oxidizing...
Old Feb 1, 2011 | 12:56 PM
krissoto's Avatar
alright guys thx I will try these methods and see how it works. thx. any other keep em coming
Old Feb 1, 2011 | 05:51 PM
eseibel67's Avatar
Greasy fingerprints prevent rust.
Old Feb 2, 2011 | 12:20 AM
stimpyster's Avatar
your going to laugh , but moth crytals the camphor vapors coat the tools with a anti rust agent when it vaporizes . and I also use a product made for machinist tools that goes inthe drawers of the box .
Old Feb 2, 2011 | 01:46 PM
properIS's Avatar
^whats the product called?
Old Feb 2, 2011 | 08:56 PM
stimpyster's Avatar
this is what I use in my machinist chest to protect my micrometers , the stuff is a little expensive but it works for a long time as long as you don't keep the drawers open all the time http://www.corrosionvci.com/corrosio...cts.php?cat=16
Old Feb 2, 2011 | 09:14 PM
Mr.Nguyen's Avatar
Will WD40 work?
Old Feb 13, 2011 | 04:24 PM
20TA02's Avatar
we use corrosion preventive compound (MIL-PRF-16173 grade 3) for our tools and its used everywhere throughout the military. especially in islands and when we deploy on boats.
Old Mar 10, 2011 | 08:39 AM
merim123's Avatar
when you buy new electronics, they have those little bean bags, throw those in the drawer with your tools for prevention.
for cleaning rust, i use a battery charger on low/laundry detergent and some rebar rods. works wonders!
Old Mar 10, 2011 | 10:39 AM
jmd's Avatar
jmd
Post
2amp?
Plastic bucket?
Detergent as in Tide or Borax?
I left some good pliers outside.
Old Mar 10, 2011 | 11:00 AM
merim123's Avatar
Originally Posted by jmd
2amp?
Plastic bucket?
yup 2amp, plastic bucket, and i used tide and oxy white (whatever the name of the infomercial stuff is) and both have worked successfully.
Old Mar 10, 2011 | 11:06 AM
jmd's Avatar
jmd
Thanks!
Old Mar 11, 2011 | 01:43 AM
jmd's Avatar
jmd
Pliers look a lot better already, as do some other pieces.
Old Mar 11, 2011 | 02:35 AM
merim123's Avatar
wait til you try control arms, motor mounts, valve covers, lug nuts... you'll have fun for a while
Old Mar 11, 2011 | 04:39 AM
6SIX6's Avatar
Siliaca Gel or sand you mean and if so i heard kitty litter in a simular bag does the same thing if left in a drawer
Old Mar 13, 2011 | 09:10 PM
bayer-z28's Avatar
That's a 10mm and an 8mm with a 1/4" ratchet. Those are easy. H/C swaps involve a bit more tools. not much, but still.
Old Mar 13, 2011 | 10:55 PM
TheSilverOne's Avatar
i wipe down/clean my tools with fluid film
Old Mar 14, 2011 | 01:35 AM
The Mighty Texan's Avatar
Today i took my toolbox apart and cleaned it really well with soap and water then used some left over motor oil (m1 5w30) and just lightly coated all my sockets/wrenches/pliers. Looked pretty good after i was done too!
