Garage cooling
Here's my suggestions-
-swamp cooler - they don't work as well as they used to because the humidity is higher in the summer than it used to be. It might be good for a month or so, but the humidity will overwhelm it in August and September. It also is hard on tools - they rust. With the amount of water they take, they are not really any cheaper to run than an ac unit. They take a lot of maintenance too
-Window AC - This is what I have now - 10000 BTU in a 600 sq-ft shop. I cut a hole in the wall and mounted it between two studs. About the best it will do is 82-83 F inside the shop and it is insulated to R26 and no windows
-Mini-split. This is what I want to try next. For around $1200 I can have between 2-3 tons of AC at a pretty good SEER. I can also have heating for the couple of weeks I need it in the winter
-Stand alone central air - 3 tons with ductwork, outside unit and air handler in the attic - $3500. The ultimate solution but too expensive.
When I built the house I had the AC contractor extend the duct and put in a register in the shop.
I got a lot of complaints from the family about the smells. If I painted in the shop, you could smell it everywhere in the house. If I had gas or solvent, you could smell it everywhere in the house. If I was welding you could smell it. If I ran a motor you could smell the exhaust.
I don't know about you, but I keep a lot of chemicals in my shop- paints, thinners, cleaners, oil gas, etc. In AZ all that crap evaporates eventually. I don't mind occasional exposure when I'm working in the shop, but the idea of exposing my kids to it continuously when the AC was on bothered me.
I ended up capping the duct and the return to install the wall mounted unit I have now
But I do leave it on all the time. Runs dirty cheap
My next project will be to hang a small vacuum hose system so I can start the car w/o opening the garage door.
I've always wanted to stick a window AC unit in the wall of my future garage. I know what you mean though. My place in NM cooked in the summer. No insulation over the garage just made it an oven. Especially with non-insulated garage doors.
Measure the area of the garage to get a cubic foot size and add 20% to that. Should be enough to cool it and not have the unit running all the time to KEEP it cool. I know how Phoenix summers are. I swear my shoes could have melted to the road. 0_o
