Garage cooling
Not sure if this is the right section, but i was wodering if/how you guys are cooling your garages? I live in phoenix an in the summer the garage is just way to hot. I dont have a window for the garage any thoughts or Ideas would be great. Thanx
It all comes down to what you want to get out of it and what price range. The cheapest and least effective would be to get a large (48") fan. Also, on a side note, is the garage insulated well? If not, just insulating can make a big difference.
I just open a bay door and the side door and run a fan. That is of course secondary to becoming less productive in the summer
Proheader
$600 and done!!!!
This option would be a total pain in the *** of course if the door needs to open regularly, but if you know you can keep it shut for a day or two it'll be well worth it.
Another option, is if you have an upstairs (I know it's hit or miss in AZ) but check where your ducting for those rooms go cause it may be no more than cutting into ducting that is already there and adding a vent. Then you're talkin hella cheap!
Another tip for helping to cool the garage. I live in hot, sunny Florida, my garage door faces the west which means the evening sun beating down on it will heat up the garage like an oven. I was looking for something to keep the heat off the door and I read about this to insulate the door, it's made a huge difference in the inside temps. Don't take my word for it, read the reviews.
Mike
