Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
The solution tool for Door Bars
Old May 24, 2011 | 08:01 PM
philsblwnz28's Avatar
Default The solution tool for Door Bars
I fought with my door bars for an hour one day and went to the tool box and found this:
I took the drill bit out and had to cut a little bit of the fiberglass out of the way so I had access to the 10mm bolts. It took 5 min after this. It is a 1inch hole saw and it goes over the welded nut on the bracket, then it's cake from there. The 15mm bolt is easy, no need for this tool.
