Welding cast manifold???
I have 2 welders.. A TIG, and a MIG.
I have mild steel wire & stainless wire for the mig.
I have mild, stainless, and silicone bronze for the tig.
The manifold in ? is a 6.0 truck manifold that I had to mill off on 1 side, for steer gear clearance. [2x4" hole]
The hole has been covered w/ 1/8" mild steel plate. The manifold can be pre/post heated. I have temp sticks to control the heating.
Suggestions as to which welder and wire would be most likely to produce the best results, are appreciated.
So far, I've tried the following:
All tig. Weld w/ mild steel, no preheat. Heard it "snap", see no cracks.
Then, preheated, same mild weld. No cooling "snap".
Then welded a scrap to a junk manifold. No preheat. Snap. No cracks seen. I broke the scrap piece off w/ a pliers. The weld let go on the scrap part. Manifold held.
Did the silicone bronze and scrap weld, preheated. Looks good, and the scrap is not budging!
I may just go w/ the silicone, pre/post heat/cool, and call it "nice"!
Getting a set of headers to fit w/ an LSX in a 55 is a PITA!
Preheated to 500* w/ a torch. Welded an inch, added heat.. repeated until I was at the point of tacking in the 2nd piece. Put it in a bucket, filled it w/ floor dry, let it sit for an hour. Temp was down to 80*. Welded in the last piece, repeated the cool down...NP. No popping, cracking. Off to the coaters!
Glad you got her figured out, post some pics when you get a chance
the aforementioed is correct.......arc welding,brazing or tig with proper prep work which is a must. use a reputable welder and the correct repair materials.
good luck have a blessed day........jim
I work at a company that specializes in cast iron repair, and we never arc weld cast iron. Ive seen too many parts that were ruined, because it wasnt done right.
Ive had to weld large 3foot diameter cast flanges to mild steel and I pre heated with several torches, and used some ni99 rod from my supplier with decent results. I dont like arc welding it though, too many worries...
With crappy castings the only way is to braze it
really cast iron, or something else like nodular / ductile
iron.
If it drills out like powder then it's cast. If it makes curlies
it's ductile and you can get away with a lot more careless
work.
work. i like this, never knew that.
