Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Air compressor - Harbor Freight - Boo!
Old Apr 5, 2004 | 12:05 PM
robertbartsch's Avatar
Default Air compressor - Harbor Freight - Boo!
I just bought a Harbor Freight air compressor; it is a small unit - 4.5 HP with a 21 gallon tank.
It worked for a few days and then crapped out!
My advice: avoid these cheapie units ($169)....
Old Apr 5, 2004 | 07:01 PM
kossuth's Avatar
Eh most of the harbor freight stuff is econo I agree but for stuff you may only use once or twice it is a good place to shop. It was cheaper for me to buy the 12 ton press and the bearing and gear puller set to redo my tranny and rearend vs the labor I would have paid. They worked fine but I have only used them twice so take that for what it is worth I guess.
Old Apr 7, 2004 | 09:55 AM
rushman's Avatar
I got the 20gal central pnuematic compressor there (online) . It took 8 weeks before I had it, and when I fired it up there was a pinhole leak where the motor bracket was welded onto the drum. It sounded like a train wistle at 80 psi. I called them up and the offered to either pay for shipping the defective one back, or they would direct ship me a new tank from central pneumatic, either way would take 6-8 weeks, so I went with the new tank since I had work that needed a compressor. The new tank works great after I switched the motor over. The only problem I have now is that its automatic cutoff is at 105psi (instead of 120) and it doesn't kick in again untill 80psi (instead of 90 to keep my tools running)
Old Apr 25, 2004 | 09:58 AM
Bugalou's Avatar
Don't they have some type of pump switch on them...On my water pump switch I take of the small square cover and I have 2 adjustment screws ...one adjusts the cut- off pressure and one adjusts the cut-on pressure...
Dave
Old Apr 26, 2004 | 08:37 AM
My Centrlial Nuematics compressor is going back to the dealer today; my Sears oil-less compressor works great.....live and learn...
Old Apr 28, 2004 | 12:27 PM
It was a pain to ship the Central Nuematics compressor unit back; I had to bolt it into the Craftsmutt Sears box and then staple the old box to the frame....call the shipping company several times to get this piece of junk out of my house.... I don't even get the refund until the box arrives at the Harbor Freight warehouse in six weeks and someone looks at it and determines if it is truly defective.... like it doesn't pump when I plug it into the wall outlet....DAAAA ..can you please return my money when UPS picks it up instead?
Next time I will be careful to not buy a large cheapie item that might need to be shipped back - it sat in my garage for a month until I got the new unit and swaped the boxes....
