Crank Pulley Install Tool
Seriously, What it is really missing is a bearing!
I have a good balancer install tool with about 8 different inserts that thread inside a huge stud for different cranks.
Unfortuneatly no insert for the ls1 crank.
But trust me the bearing takes a lot of load off the stud threads and makes the install much much easier. It does have a wrench head on the stud as well.
Add a bearing to your kit and it will last a whole hell of a lot longer before you strip the stud and nut.
Why don't you do that and keep the cost at $25 shipped and make it worth the time and trouble to even mess with. And don't forget the $2/gal gas you burn every time you run to the post office. Also, the stud I sell is class 8.8 and the nut is class 10.8. Keep the threads lubricated and it will not strip.
Metric class 10.9 is equal to Grade 8.I made one like yours and with a tight fitting damper like the ATI it stripped out after about 3 -4 uses.
I now use a long Class 12.9 bolt along with a bearing and it works great.
I have used the same setup like 2xLS1 had been using for a while before that and can probably get 10 installs out of it if I'm carefull, I have no idea what grade the threaded rod was though. What happens a lot is the washers will start gouging the threads on the stud when they spin and the nut gets jammed, the bearing would help some in that case. S_J_H is far from being a troll, he was just pointing out some weaknesses. I dont think its a bad deal for occasional use, that 25.00 is a heck of a lot cheaper then the sinking feeling you will get when you pull the first couple threads out of your crank using the stock bolt to pull the balancer on
If you dont have access to a place that sells that threaded rod or a nut that size its a fair deal considering thats the shipped price...
Good luck with your tool.
Steve
The simple one works great for me, its not like I swap pulleys more than a couple times per year.
If you don't like the one offered here, www.JCW.com - sells a tool for $29 (Part sf147601B). It has eight threaded attachments for EVERY different motor application - foreign and domestic!
The stud version pulls against ALL the available threads and doesn't grind against them.
A great idea!
And like it has been stated ... buy his for $25 delivered or spend $20, 1/2 a day chasing parts and fab your own.
