Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
LSx engine lift plates
Old Dec 5, 2012 | 11:42 PM
MonzterMtrSprt's Avatar
Restricted User
Default LSx engine lift plates
thinking about making my own engine lift plate. i have a full shop. gonna make two of them one for me and a friend. anyone else need one?
was gonna make a plate that captures the middle 6 bolts but can also be used with the valley plate still on. will turn some stand offs in the lathe to achieve this.. thanks
Old Dec 11, 2012 | 06:27 PM
Jesse_P's Avatar
how much would you charge for them?
Old Dec 13, 2012 | 04:33 PM
Drednot's Avatar
I would be in for one. How much?
Old Dec 17, 2012 | 07:33 AM
ART T's Avatar
Are these plates strong enough to lift the engine and tranny together? Are six bolts enough?
Old Dec 21, 2012 | 01:23 AM
75 Big Bumper's Avatar
Default engine lift plate
I was actually just needing something like what you described. I tried to mount my 2000 camaro ls1 in my 75 fbody to see if my new swap mounts would work, but my engine was too low. The oil pan hits the engine kmember just enough to make the engine mounts not work, but in addition to that, the sump of the pan also hangs below the kmember about 3 inches. I was looking for something that could hold my engine up 3 more inches. I know my mounts will work, I just need something to go in between them for that 3 inch lift. Pm me if you can.
Old Dec 27, 2012 | 03:53 PM
Default Oops
Oh wow. I COMPLETELY misunderstood what you meant by engine lift plate haha. I was thinking you meant engine adapter plates that would lift the engine up a few inches xD
Old Dec 27, 2012 | 06:18 PM
MUSTANGBRKR02's Avatar
I just use one for a 4bbl carb and modified the holes to work on the valley.
Old Jan 3, 2013 | 01:01 PM
nothngbtagthng's Avatar
I might be interested. Price?
Old Jan 6, 2013 | 08:24 PM
crunkride's Avatar
Interested too...but need shortly (pulling engine soon), needs to be plated or corrosion resistant, and strong enough to hold engine/tranny combo. Please PM if your design will include these things, and include price and I am in.
Old Jan 6, 2013 | 10:41 PM
DietCoke's Avatar
The allstar plate is so cheap at $59, hard to go wrong, and it works, and it can be used with the valley cover in place (with bolts removed)
Old Jan 6, 2013 | 11:35 PM
slowvw70's Avatar
price?
Old Jul 9, 2014 | 11:29 PM
Poncho72's Avatar
would anyone with a valley mount LS lift plate be willing to get me some measurements on the valley plate width and length, and hole size and spacing. i don't have an engine yet, but have the materials to make one versus spending 60+ dollars on something i could build in about an hour. i only need the specs from the plate, not the lifting bar since i already have an engine load leveler.
