Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
.0001" Dial Indicator
Old Nov 19, 2013 | 09:08 PM
badazz81z28's Avatar
Default .0001" Dial Indicator
I need to use one to set up some hubs...No intention of ever using it again. Can anyone suggest where to get one? Not overly priced, but no so cheap it's not accurate.
Thanks,
Old Nov 19, 2013 | 11:45 PM
Blown06's Avatar
8 Second Truck Club
If you want one to go out that far your gonna spend some big bucks.
Did you mean .001"?
Old Nov 20, 2013 | 04:26 PM
Jenson's Avatar
We have a few of these, cheap and decent for what your doing.
http://www.mscdirect.com/product/80740723
Old Nov 21, 2013 | 05:46 PM
CTSmechanic's Avatar
when you say set up hubs to you mean for bearing preload and end play or runout? .001 is all ive ever used.... ive done stuff thats sat on the pole at daytona and taladega...
Old Nov 22, 2013 | 08:12 AM
I bought the KORE3 spacers for the bearings on my 78 Camaro and his instructions state to set the end play to .0005-.0015". Hard to do that with a .001" indicator.
Old Nov 22, 2013 | 01:16 PM
usdmholden's Avatar
In the resolution you are looking for, you want a test indicator rather than a dial indicator. Granted, test indicators have "dials" so the differentiation can be a little confusing.
The primary difference between a test indicator and a dial indicator, is that a dial indicator has a large range of motion at least a half inch or so (typically 0" to .5") and is typically graduated in .001" increments, while a test indicator has a range of motion usually around .030" total (typically shown as -.015" to 0" to +.015" on the dial) and is graduated in .0005" or .0001" increments. Obviously the .0001" graduated units are more expensive than the .0005" graduation units, and the ranges I gave above are examples, other ranges are available.
The test indicator that Jenson linked to looks nice. If I had seen that when I bought mine, I might have bought that instead. I actually bought mine as a kit with .0005" resolution. I bought the kit to make it easy to mount and primarily I use it to tram the vise or fixtures in my milling machine.
http://www.use-enco.com/CGI/INSRIT?P...PMAKA=328-0962
Old Jan 29, 2014 | 04:43 PM
v8pwr's Avatar
The difference in cost between a .001 to .0001 indicator is pretty minimal. The brand/quality will determine the price. Dial indicators are larger than Test indicators. The tighter tolerance one will have a smaller range of movement. You will also need a way to hold the indicator. You can usually find a magnetic base and indicator combo pretty affordably. The SPI stuff is just branded Chinese stuff. You can save some money and buy the Chinese no name and get the same thing.They work and will get you by. See if you have someone local to you and offer them some beer.
Old Mar 2, 2014 | 02:32 AM
truckdoug's Avatar
Originally Posted by jim1450
That's funny, I'm a tool & die maker @ the former GM/Delphi plants that still makes many of the OEM GM spindles & hubs. They are starting to use Asian companies now for some of them so I can't speak for those.
We work in millionths, some dimensions & specs are as tight as 50 millionths.
We also hand build & assemble spindles for some race vehicles, I was told those are held to tighter tolerances.
i worked in T&D for photolithography semiconductor. we used sharpie ink as shim stock. (20 millionths or so)
glad to be back in the real world making parts and shootin chips.
OP means .001" amirite or amirite?
