GM Terminal Removal Tools
With that said I am looking for a company that sells the GM MetriPac and Weather Pac TERMINAL REMOVAL TOOLS......you may have seen them in a Technicians tool box but had no idea what they were for unless you observed the Tech using them to DE-Pin wires from connector bodies. The two most common are the round Yellow tool and the Green Flat blade tool.
ANY help is greatly appreciated.
Have any Admins considered an Electrical Forum all its own or is it best left to subheadings requiring hours of searching?
Those two tools will depin 99% of all GM connectors you run across
These are good all-in-one units but hurt to use for long periods
http://www.ebay.com/itm/Lisle-14900-Wire-Terminal-Tool-and-Trouble-Code-Tool-/400781338003?hash=item5d506de593&item=400781338003&pt=Motors_Automotive_Tools&vxp=mtr
Barrel style weather packs require an actual tool, but most push-to-seat terminals can be removed with a paperclip
http://www.mouser.com/
Almost anything Delphi You will ever need. Stan.
