About to pull the trigger on a MaxJax
The only draw back is with the garage closed I could get as much as 60"+ clearance but the jack only goes 48-49" with the extensions. Is this a good buy or does anyone else know of something similar with a little more height on it?
I don't think you will suffer not being able to go the additional 6" due to the lift being maxed out at 54".
Why not look into making some custom spacers to get your 60"? Lift car up a foot or so. Lower car back down on jackstands, install custom taller spacers and lift car again to max travel of lift. Done.
I was spoiled when I got into cars because a friend of mine had a full size lift. So IMO I wouldn't want something unless it is a full size lift. BUT you need a much taller garage ceiling for one.
I might actually entertain this when/if I get a house. But the ceilings would be maybe 6" above the garage door when open which is a worse situation than you.
If you could, post a picture of the car lifted as high as you can and stand next to it to see a height relationship....or stack some tires next to it to see.
im 5'11 and would like something that could lift it high enough for me to set under it on a roller chair. Ive got a restoration on a 70 camaro coming and it would be nice to get it up high enough to work on to set the rear suspension.
still undecided i guess
This thing will be the best money you spent. To be able to roll around under my car and access 99.8% of everything with nothing in my way is priceless. A scissor jack would just get in my way. The amount of work I've been able to knock out has doubled in the same time frame, not to mention I'm comfortable doing so. The lift will raise the vehicle 48" and 51" with the truck adapters. 51/52" is plenty if you ask me and I'm 6'2. Buy yourself a stool that is about 17" off the ground or less and you'll be golden.
I have a full height 2 post lift, but couldnt get it into the house im in now, and the building I had it in has been over run by my family's junk...... such is life.
i agree with you on the scissor lift giving some limited access by comparison. if you have worked under a 2 post lift ever you get kinda spoiled with the amount of access you get.
so on just pads you can get 48"? sounds like my decision just got made i think.
though something i am curious about and if you dont mind could you give me a rough estimate the size the base plates are? I have snap down flooring in my garage and my plan was to make two 2'x2' sections removable for where the anchors would be mounted than i could cover it back up when im not using it
If I ever got one I would like to use threaded inserts in the ground that you simply use bolts to secure it. When you are done you can remove the posts and have no studs sticking out of the floor.
Word of advise (if you don't have the drill bits and a big hammer drill) Just rent a hammer drill from home depot etc. The drill bits come with the rental which is badass and the whole thing costs about $50 to rent. The drill bits where over $50 if purchased separately.
Installation tip:
Once you pillars are in place, Take the 7/8 drill bit and start your hole (any one is fine for the first one.) Once you have drilled a1/4" or so pull the 7/8" out and throw in your pilot hole bit (5/8") and drill the remainder of the hole with this. After you reach your target depth go back in with the 7/8". Once the hole is cleaned and ready, Bang your anchors in and tighten the bolt down pinning the column (don't torque it just give it a good tighten to prevent the column from moving.) follow this step for the rest of the holes and you will have (10) perfectly drilled/located holes.
It is extremely difficult to perfectly line up your pilot hole dead center everytime and will likely leave you with mis placed holes. The 7/8" drill bit is damn near the same size as the 1" hole so that's why I say to start with that. It will give you a perfectly centered hole everytime.
With that said I am still able to roll around without any trouble.
