Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Ls1 swap
Old May 30, 2016 | 11:51 PM
FGax9's Avatar
Default Ls1 swap
Hi im putting an ls1 on my 1985 chevy c10 shortbed and I honestly don't want to change my driveshaft im on a budget build nd i dont want to spend money on tht.. Do you guys know of any motor mount adapters that work? If you guys could please help me out
Old May 30, 2016 | 11:52 PM
FGax9's Avatar
Ooh I forgot im putting an 4l60e
Old May 31, 2016 | 08:54 AM
JoeNova's Avatar
Restricted User
Where are you located?
If you're swapping transmission as well, you should measure total length of the old one vs the new one to know how far forward/backward to set your engine.
If the 4L60e is 2" longer from the bellhousing to tailshaft, then you'll need to sit your engine forward 2". There are literally HUNDREDS of adjustable mounts, sliding mounts, etc.
Old May 31, 2016 | 11:45 AM
FGax9's Avatar
Im located in Phoenix Az.. I appreciate the help honestly
Old May 31, 2016 | 05:25 PM
orange88ls1s-dime's Avatar
Driveshaft mods are cheap and shouldn't dictate where the motor goes
Old Jun 1, 2016 | 11:03 AM
scout2000's Avatar
What Orange88 said.
your drive shaft should come last. Choosing optimal locations for your major drivetrain components is always the best way to go.
