cylinder head porting tools
Just curious what you guys use to port cylinder heads? From die grinders to ???
All the different burr bits and sanding bits. Maybe post pics of the cut and the removal rate at each step?
I'm not exactly trying to get into porting heads, but I have some other aluminum fabrication planned and could use much the same tools I would imagine you use for porting heads.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
