How many LED light needed?
I've got 6 4ft LED fixtures in my front portion which is 20x24 and 8ft high
good enough lighting to check for bubbles when I'm doing fiberglass work or rebuilding a carb
my rear portion is 18ft high and is 20x40 and I'm using 2 Phillips high bays
probably is enough lighting to film a tv show in there
definitely happy with the hydro bills too with LED
Last edited by orange88ls1s-dime; Jul 2, 2018 at 02:40 PM. Reason: Left something out
I'm really glad to hear you are moving into a garage because surely that means you will get back to work on the Camaro!
I am considering putting in 4 sets of LED lights but wanted to ask if anyone has recommendations or cheap alternatives. I am already stretched pretty thin from buying two project cars, so a cheap option may be the way to go. I have electrical experience and know how to do the wiring and installation.
The ceiling is too low for drop lighting, so ceiling flush mount would be preferred. Does anyone have recommendations?
now the complete fixtures seem to work fine so maybe it's just a matter of removing the ballast (even though the dang box says not to)
The instructions on them say to take the ballast out, wire direct, thru the tombstones.
Do the instructions on yours say either way, with the ballast? Where did you get them?
Are they 4, or 8'? I've seen some 8'r's, that sag when heated up. If that's the case, it could be, the bulbs are pulling out of the sockets, far enuf, to cause a lot of heat.
Most suppliers have clips to add in the middle of the bulbs to stop this.
I'd try to go direct w/ the line voltage, and delete the ballasts. 110 on 1 end, neutral on the other, daisy chained.
Clips:
https://www.bing.com/search?q=8%27+led+center+support+clips&form=EDGTCT &qs=PF&cvid=ba5ebb4a36194b2a98ab2033528195d4&refig =78ed2833d5094aaeb2aa0302c1345e5e&cc=US&setlang=en-US&elv=AQj93OAhDTi*HzTv1paQdngMqSx94Cxcxl9EvGCoPfr ZevXGXzHPNxdDHiLFxbJeNs4kR8P0h9%211HNLd71WNwA*zwCg dK93JiZtsKISz2Jn*&plvar=0&PC=ASTS
HTH,
The ability to "aim" them, is nice. I can turn the bulb and watch the walls get more light on them. Nice to be able to see the shelving contents.
