Need a brake line flaring tool
I had the issues with the master cool on stainless, the double 45° did not work well nor did the quick disconnect fuel line flare. It seemed weak, not strong enough to complete the flare.
I like the tube cutters, they cut square. I will use a drill bit or step drill to clean out and debur the inside of the tube after cutting, that makes things go smoother.
The aftermarket, including SJM, almost exclusively uses inch size tubing because it's less expensive. And almost all the tube nuts you buy from the store are also made for inch size tubing.
If you try to slip an OE tube nut for 6 mm line onto a 1/4" line, then you'll see it's too tight. But those sizes are close enough that you can drill out the center of the 6 mm tube nut and use it on 1/4" line. And likewise, you could use 6 mm line with a 1/4" tube nut and still make an adequate seal with the flare.
The fuel quick disconnect definitely doesn't look as nice as an OE crimp, that's for sure, but all the crimp does is retain the fitting so it doesn't back off. Sealing is o-ring to tube. Trouble with sealing is probably because the tube is out of round, or tearing of the o-ring during assembly. Lead-in chamfer, diameter, roundness, and surface finish are critical to an o-ring seal. You want a 37° lead-in chamfer on the tube ends where the o-ring slips on to avoid tearing. And the rollers of a tube cutter compresses the surface and can cause a leak. That's why I use a band saw for those kind of cuts. Got to have a pristine surface finish for an o-ring seal.
Also, buying tube in bulk and straightening using a 5 roller set (like Jegs sells) makes the tube out of round. Manufacturing facilities have gobs of rollers to straighten a tube and we can't come close to duplicating those kind of results at home. So personally, I only use factory finished, straight tubing if there is going to be an o-ring seal.
The quick disconnect fuel flare is the same as a the flare on a power steering line with the rubber O ring. On the fuel line it is there to retain the fitting as you mentioned. On the power steering it seats the O ring and makes the seal as well as a stop to keep the tube from slipping out of the tube nut. When I tried the Mastercool tool it was unacceptable, I could pull the fuel line retainer off by hand without much force. In the same instance if it was to be for a power steering type of application it would have allowed the O ring to stretch and roll over the flare. Just not as sharp and precise as the factory or the old Matco tool which could replicate it on stainless. I do buy bulk tubing and I do use a 5 roller straightener and I do have success with the fuel line flare after utilizing the roller straightener. I will admit that I had an issue with the tube collapsing from what could have been an out of round condition from the roller or factory. It was the last piece of a previous roll of tubing, went to a new roll and no problem after that.
