Need a brake line flaring tool
RIDGID 83037 Model 458R Precision Ratcheting Flaring Tool, 1/8-inch to 3/4-inch Pipe Flaring Tool
That Ridgid flare tool makes SAE 45 degree flares. Automotive brake lines are either/or/both 'double flare' and 'bubble flare'. Tubing seats for double flare have a tapered protrusion. Tubing seats for bubble flare have a conical depression.
But in UK/Europe, this is the best portable tool about.
https://www.sykes-pickavant.com/prod...aring-tools/65
You can get various vise mounted tools too that are excellent as well
https://www.sykes-pickavant.com/prod...ring-tools/553
I know it’s not the cheapest but think about what’s at stake. You, your passengers and others can be injured or killed with a bad flare. I understand people have made successful flares with the traditional clamp style flare tool for years and that’s fine. Me personally, I value my life and the lives of others so safety is not something I will make a compromise with.
It needs a proper tool like I mentioned for that.
If you dont need portable, then the vise mounted ones really are great and fast to use. The portable version a little slower. But both produce excellent flares even in steel, although I'd never use steel pipe myself. But sometimes you need to flare OEM steel pipe.
https://www.eastwood.com/professiona...ring-tool.html
That's an old classic vise mount setup. Almost impossible to go wrong, and they always produce great flares.
This is true.... BUT you can make both those with a standard flare tool from Napa. It’s not meant to make both types, but you can get it done. My entire car was done with a standard flare tool that you can buy cheaply. And with practice my flares were better than mediocre.
I get the best results when cutting tube with a band saw. Super clean cut without deformation. And I've tried many brands of tube nuts from cheap to super expensive. Edelmann brass nuts gives me the best leak-free joints on brake lines.
Stainless hard lines are a bitch. The material is so strong that it doesn't form a seal without really high clamping loads. You need tube nuts that can handle the tightening torques. I stay away from stainless lines unless it's a factory bolt-on deal. If I'm making something at home it's either going to be steel or ni-cop.
