Better floor jack for lowered car
I tried some ramps, but they have just slid all over the place, and the ones that are meant for lowered cars still don't raise the nose high enough to get a jack in there.
Anyone know of a jack somewhere (or have any ideas) that will fit? It's getting to the point where I don't want to work on the car because getting it up and down is such a process.
And before anyone suggests a lift... I rent, so drilling holes into my garage floor isn't an option, and the ceiling in my garage is incredibly low, so even "short" lifts won't clear the garage door.
Drive the car just short of where you want to work on it, put the ramps in front of the tires, drive up and then jack it like it is a normal car.
Surprisingly my Taurus SHO is actually more of a problem stock than my lowered f-bodies that I can't get on my rhino ramps which are no problem with my f-bodies.
Someone suggested quick jacks. I don't know how finicky the bleed procedure is, after initial setup, but if frequent re-bleeding isn't necessary, and you have the room to stow it away when not in use, quick jacks might be the way to go.
Basically, exactly like this. Except mine are held together by locking hooks so I can completely remove the ramp part, instead of having permanent hinges on them. I use the ramp part as a step if I need to rewach further into the engine bay.
This works on my C5, lowered Tahoe, lowered fbody and everything else so far. The process of pulling these out of the corner, then lining up ramps with mats and tires, then getting back in to drive up the ramps, then getting a jack under it, then placing jack stands, then FINALLY start working on it.... yes PITA. With the front end supported on the ramps I still have enough room under the rear to get the jack under there.
