Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Ac schrader valves tools
Old Feb 15, 2022 | 12:19 PM
95maroz28's Avatar
Default Ac schrader valves tools
Does anyone know of a thicker schrader valve remover tool for the m10 size ac line schrader valves? I used one and it was so thin that it snapped both edges. They aint but a 1mm thick on the sides. There has to be a better tool or schrader valve remover with thicker ends.
Old Feb 15, 2022 | 03:29 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Aren't some AC valves 'left hand' threaded ?
Or is it the evap test port valve is left hand thread ?
When I worked at a Tuffy, there was a left hand thread port.
Old Feb 15, 2022 | 11:22 PM
95maroz28's Avatar
I dont know the tire valve stem core low side was no problem the high port m10 or 10mm schrader valve broke the tool. Is there a thicker heavy duty 10mm schrader valve tool?
Old Feb 16, 2022 | 06:03 AM
samckitt's Avatar
Don't know, does this look any better:
https://www.grainger.com/product/45J...B&gclsrc=aw.ds
Old Feb 16, 2022 | 11:32 AM
1FastBrick's Avatar
Try one like this where the tool shaft doesn't reduce in size at the opening.
https://www.ebay.com/itm/33235262956...8AAOxy4YdTREl~
