Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Cleaning engine block deck
Old Jun 26, 2025 | 11:11 AM
goatmanls2's Avatar
Default Cleaning engine block deck
What tools are you guys using to clean engine block decks as well as all sealing surfaces?
Old Jun 26, 2025 | 11:58 AM
Alaseh's Avatar
I use scotch Brite pads all the time, works great. Spray a little brake clean on the pad then rub. (edit after reading other people) yes they can leave residue and you have to make sure to clean it up after, don't just rub it in and leave it.
Old Jun 27, 2025 | 08:30 AM
goatmanls2's Avatar
Thank you for the reply! I will give it a shot.
Old Jun 28, 2025 | 08:25 AM
Old Buzzard's Avatar
Just remember what a Scotchbrite is made of......
Old Jun 28, 2025 | 08:34 AM
Rich-L79's Avatar
I wouldn't go anywhere near internal engine parts with a Scotchbrite pad that couldn't be sent through a parts washer afterwards. To clean the deck I just use plastic razor blades (aluminum block) or regular razor blades (iron block). Tedious, but gets everything off. Then go over it with a shop vac and lots of brake cleaner. Be sure the bolt holes are cleaned out and dry.
