Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Fuel Injector Clearance Issue
Old Jul 31, 2025 | 11:01 AM
charna34's Avatar
Default Fuel Injector Clearance Issue
Hey all,
Running into a bit of an issue with fuel injector clearance on my LS intake. Switched to a different set of injectors and now the height is off just enough to mess with fitment—rail doesn’t sit right and the connectors feel like they’re at a weird angle.
Before I go hacking things up, I’m thinking of fabricating a custom spacer or adapter to clean it up—maybe 3D print a mock-up first before making something more permanent.
Has anyone done custom plastic fabrication like this for injector fitment? I’d really appreciate any advice or examples if you’ve run into something similar.
Thanks!
