Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Magnetic base dial indicator on alu block
Old Aug 23, 2004 | 09:19 PM
11 Bravo's Avatar
Default Magnetic base dial indicator on alu block
How are you guys attaching the dial indicators on our aluminum blocks? Fabbed metal brackets?
Old Aug 23, 2004 | 09:50 PM
taqwache's Avatar
good question. my block is iron so i did not have that problem. what are you trying to measure?
Old Aug 25, 2004 | 03:27 AM
robertbartsch's Avatar
bolt a hunk of ferris metal to the block;;;;; the magnet holder will stick like majic to the ferris metal ....
Old Aug 25, 2004 | 11:07 PM
Jason99T/A's Avatar
I can shift faster than you.
If you are trying to measure thrust (crankshaft end-play), attach the magnetic base to the main cap.
