Are crowsfoot wrenches very useful?
set of stubby metric 8-19 ( I also have a set of racheting long and short and reversable mid metric) a set of allen and torx (plus tamper proof torx) head sockets.
A couple pry bars, pliars screw drivers. Set of short mid and long metric sockets 1/4
short and deep 3/8 sockets and a set of long 1/2 should get you through 99% of what you come across and lots of 3/8 and 1/4 swivels adaptros and extensions . I use a snap on 1/4 drive 6 inch locking flex head ratchet for 70% of what I work on. Short swivel sockets are also your friend--> 10mm 13mm 15mm 1/4 drive and 16 mm 3/8 impact (for them bastard trannie bolts) crowsfeet will be very use full should you ever get screwed into doing a clutch assist line on a turbo. Also a pair of hose clamp pliers with the cable are worth their weight in gold. decent mulit meter and a test light maybe a soldering iron and some air tools (ir all the way) and your pretty good to go. any more questions feel free to ask.
Cody has the right idea though; the PS lines are easier with an 18mm flare nut / tube wrench style crows foot. I will pick that one up next time I need to do a box / pump.
I'm wondering if the right one would make older (non quick disconnect) GM threaded trans. lines easier to deal with. Any thoughts on that guys?
