Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
help w/tools please...
Old Oct 22, 2004 | 07:46 PM
GreekGator's Avatar
Default help w/tools please...
ok, i have a really small knowledge when it comes to tools....what are the basic kinds of tools besides wrenches and sockets??where could i learn more about tools b/c i would like to start doing things to my car......someone with knowledge would be very much appreciated....tia
Old Oct 25, 2004 | 12:50 PM
transamdude99's Avatar
Screwdrivers,ratchets,sockets,wrenches,impact guns,torque wrench,pliers,hammers,jack,jackstands. What exactly are you going to do to your car?? Depending on what your doing you may not need some of them tools
Old Oct 25, 2004 | 01:26 PM
2_wacko's Avatar
You might to get some ramps and a tool to remove pullies.
Old Oct 25, 2004 | 11:26 PM
Compstall's Avatar
Of all the tools I own, I swear my FAVORITE tool, my right hand man, is my scribe. I use it for all kinds of things; pulling seals, digging out the dried RTV from the tube, cleaning my fingernails, etc..
Old Oct 26, 2004 | 06:58 PM
GreekGator's Avatar
whatever i plan to do down the future like a pully,throttle body, maybe even rearend and tranny work...i just wanna know my tools and become very knowledgeable about them...thnx for replys
Old Oct 26, 2004 | 10:13 PM
2002 Trans Am's Avatar
Rhino ramps are very helpful
Check out the mechanic tool sets they have a Sears, comes with mostly everything you need, I like to pick up other tools as they become necessary.
A sawzall is a lot of fun, especially when your going to town on stock exhaust.
For the pulley your gonna need a TQ wrench that goes up to 250lbs, throttle body is just a few screws, the tranny is going to require a few other tools (1st off my head is a really really long extension for your ratchet)
Old Oct 27, 2004 | 03:08 PM
chupr0kabra's Avatar
Tools I owned before I started working on my car:
Screwdriver set
Metric and SAE 3/8" socket set
Metric 1/4" socket set
Metric wrench set (10mm-17mm)
Pliers (slip neck and needle nose)
Adjustable crescent wrenches (3, various sizes)
Vise grips
2.25 ton jack
3 ton jack stands
Tools I have bought since I started working on my car:
Rhino ramps
3 ton jack
3 jaw puller
20-100lb 3/8" torque wrench
100-250lb 3/8" torque wrench
Metric Gear Wrench set (swivel head)
3/8" Breaker bar
30 gallon compressor
Air ratchet
Air impact ratchet
Large C-clamp
3/8" Torx sockets (T25-T55, I think)
32 oz. rubber mallet
Ball joint remover
Strut spring compressors
Porter Cable 7336 sander/polisher (I know, not really a tool, but it gets used a lot)
-Mike
Old Oct 27, 2004 | 06:44 PM
SidewaysTA's Avatar
A scribe is very good to have.
Right now my favorite tools are my wobble extensions. Saved me more than once.
Mike
Old Oct 27, 2004 | 08:32 PM
chevymec's Avatar
Also some gear wrenches save some time in certian cases. Id say to go to sears and a tool kit from them is prob a good start to having some basics.
Old Oct 28, 2004 | 05:04 AM
Predator's Avatar
Aside from the tools metioned, a Dremel tool has been worth it's weight in gold. Sometimes you just don't have the room to use to use a hacksaw. With the Dremel you can have the tool stationary and cut away. It's been a lifesaver many times.
Old Oct 28, 2004 | 09:00 AM
It certainly does help, I turned my friends true dual exhaust into a slip fit exhaust with the dremel otherwise we couldn't fit the damn pipes together
Old Oct 28, 2004 | 09:16 AM
Amen to the Dremel. I have one as well, though I have yet to use it on my car. It has come in very handy for several other little projects around the house.
-Mike
Old Oct 29, 2004 | 04:31 AM
Predator's Avatar
A "soldering iron" is very handy too.
A "pipe expander" if you do lots of exhaust work.
A small drill press.
A bench grinder with polishing and grinding wheels.
A punch set, and an awl.
A hand-operated pump for removing tranny fluid.
Various crowbars, and breaker bars.
"Drill Doctor" for sharpening bits.
"Sawzall."
