Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Ls1 crank holding tool
Old Dec 31, 2004 | 07:14 PM
code4's Avatar
Built two more tonight. Hows $40.00 plus shipping sound for a trial period. Get a few out there and see how people like them.
Old Dec 31, 2004 | 11:15 PM
SS SLP2's Avatar
may make a tool to hold flywheel
hope the drawing of tool is understandable
use a 1/8 x 2 flat bar about 12 in long insert into flywheel threw the round hole in botton of bellhouseing ,the notch in side will hold tool in place
PS:::
for some reason my drawing will not post right >>the base of the tool should be as wide as the top part with the teeth
Old Dec 31, 2004 | 11:28 PM
code4's Avatar
PS:::
Why don't you make one of these that i just made then you wouldn't have to remove the starter. If you have an ASP pulley then it is very simple to make. The hardest part is making those two shafts to hold the stock pulley.
Old Jan 1, 2005 | 04:52 PM
SidewaysTA's Avatar
I'm looking at getting a March pulley. Would it work for a March pulley? Anyone know?
Mike
Old Jan 1, 2005 | 06:17 PM
code4's Avatar
Mike
I asked the same question with no answer. I bet the bolt pattern is the same but would like to prove it. I'll let you know if I find out.
Old Jan 2, 2005 | 04:42 PM
618HAWK's Avatar
Not to be a pain but what happens when you have a different balancer ati ect forced induction set up. Work great on the stock dampner but what about the others.
I am thinking more on the lines of a univsl strap wrench that will hold all.
chris
Old Jan 2, 2005 | 07:38 PM
code4's Avatar
chris
That's what the 3 holes are for, it will bolt up to the aftermarket balancer with the 3 bolts that are included.
