Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Organizing sockets
Old Dec 23, 2004 | 12:50 AM
Shamrock98TA's Avatar
Default Organizing sockets
Anyone have a good way to organize sockets? I bought a set of the organizers from sears that has the pins you pop into the boards, but those things are worthless. Didn't have enough pins for the sockets and they don't sell extra pins. I saw some other trays/holders, but I would be spending close to $100 to get enough for all my sockets.
Right now I'm planning on taking a 2 x 4, ripping it to 3/4 x 3 1/2, drilling some holes in it, cutting some dowels and putting them in the holes. I'll take a label maker and print off the sizes for easy recognition.
Anyone have a better way to do it?
Old Dec 23, 2004 | 08:30 AM
transammanv8's Avatar
I went to sears and bought the foam pads that you trace around your tools and cut on the lines. Works better for me than the clips. I just had to cut the holes slightly smaller than the actual sockets. I took a silver sharpie and marked the sizes on the black foam, and I think it looks great.
http://www.sears.com/sr/javasr/produ...id=00965417000
Old Dec 23, 2004 | 08:53 AM
I'd snap a pic, but my tools are locked up at the airport until school starts back.
Old Dec 23, 2004 | 09:16 AM
robertbartsch's Avatar
Sears does sell the extra plastic gizmos to add to the tool holders...
Old Dec 23, 2004 | 11:40 AM
Boostaholic's Avatar
Here is what I have
http://www.sears.com/sr/javasr/produ...id=00933932000
3 for metric, 3 for SAE (have a 6 point, 12 point and misc set of each) and they work GREAT, I would buy them again in a heartbeat.
Old Dec 23, 2004 | 12:17 PM
What about the magnet holders; i think they are pricey, however....
Old Dec 23, 2004 | 11:10 PM
Judd's Avatar
Yep, I like the magnetic holders from Lisel. On one side they hold shallow well. On the other,,, they hold deep wheel. One great thing about them is that you can pick them up and take them with you if need be.
Here is a link-
http://www.sears.com/sr/framework/ho...sp&brand=Lisle
Old Dec 26, 2004 | 02:44 AM
I like those. I have a Snap-on box however, so I'm not sure if those would fit exactly right.
I'll check around home depot and lowes for just some foam sheets like that. Probably be able to find them in bigger sheets and cheaper. Those would also be good for all my handtools, make it easy to see if I'm missing anything. Also, for christmas I got a label maker, so I could use them on the foam for really quick identification of all sizes.
I like the Hansen holders, but would need so many of them.
Old Dec 26, 2004 | 11:41 AM
I know what you mean. I had to trim the pads to fit my 40" by 18" box and there are seam lines that don't look too great. One big piece would look much better.
If you go this route, cut the holes for the sockets smaller or they will not fit tight. If you use it for wrenches, cut all the way through the foam. Then, take the part that you cut out and cut it in half. This will allow the wrench/pliers/etc... to sit slightly inside the foam, but still stick out above the foam, making them easier to pick up.
Old Dec 29, 2004 | 06:27 PM
98TXFBODY's Avatar
From: Used to live in South Texas, Now in North Carolina
Originally Posted by term
Here is what I have
I agree, I have had every other kind and gave them away. Those trays are the best hands down.
Old Dec 29, 2004 | 08:36 PM
Nate_Taufer's Avatar
Yeah but all of my taller drawers are packed full and the smaller drawers in my tool cabinets are not that tall. i suggest the 1.xx specials at sears that have the long piece of metal with the small metal brackets. just pop em on and then lay em sideways in the box. they work great for me. Plus if they get worn down and wont hold the socket all the way on and keep slipping off, just slide a screwdriver in the middle and pry both ways and they widen back up.
Just my suggestion.
Nate
Old Dec 29, 2004 | 10:19 PM
LawmanSS's Avatar
I have these, currently...but I don't like them very much...they waste a lot of space.:
http://www.sears.com/sr/javasr/produ...ge+Accessories
Old Jan 3, 2005 | 10:41 AM
Jax White TA's Avatar
Another vote from me for these.
Old Jan 21, 2005 | 01:38 PM
Naboo's Avatar
Here is what I have
How many many inches long is the longest pin, from the bottom of the tray to the top of the pin.
Old Jan 21, 2005 | 01:40 PM
Scream's Avatar
Not exaclty sure but they fit in the 4" deep drawers in my Craftsman toolbox.
Old Jan 21, 2005 | 01:46 PM
I think they are 2.96
I will mesure it when I get home.
Old Jan 21, 2005 | 06:54 PM
mitchntx's Avatar
Here is a link-
I have those as well ...
It allows me to store my sockets in shallow drawers ... I have a LOT of more shallow drawers than I do deeps ...
Old Jan 21, 2005 | 10:18 PM
Naboo's Avatar
That would be great!!!
Old Jan 22, 2005 | 02:31 PM
Tech's Avatar
I have mine on a rail. When you're on your back under a car, it's nice to bring the entire rail with you.
