Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Difference between blue and red Loctite?
Old Feb 22, 2003 | 08:45 PM
mass's Avatar
Default Difference between blue and red Loctite?
What's the difference?
Old Feb 22, 2003 | 11:32 PM
9T9BlueTA's Avatar
Default Re: Difference between blue and red Loctite?
I think its how hard it sets. Red will set hard and is for screws you arent likely to remove.
Blue sets softer and is easier to remove if needed.
There is also a green. Used for industrial mainly, that one is almost like welding the screw in there.
<small>[ February 22, 2003, 11:33 PM: Message edited by: 9T9BlueTA ]</small>
Old Feb 22, 2003 | 11:42 PM
mass's Avatar
Thanks.
Old Feb 23, 2003 | 04:10 AM
DARK AGE 53's Avatar
This link might help, http://www.loctiteproducts.com/Locti...ID=10&SubID=48 .
Al
Old Feb 23, 2003 | 09:41 AM
MacGyver's Avatar
The green loctite is actually a penetrating solution that you can put on bolts that have already been tightened. It is alot thinner than the others and allows it to get in there with the parts already in place.
Will
Old Feb 23, 2003 | 09:57 AM
Argon Z's Avatar
There is at least 10 different kinds of red loctite.
I used different numbers of red loctite for what the job requires.
examples are #271=strong #262=strong but weaker then 271.
Old Feb 24, 2003 | 12:18 AM
mass's Avatar
Good link,thanks for the info.
