Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Tim's Valve Spring Tool Now Available
Old Mar 27, 2006 | 12:10 PM
  #161
ThirdGenLS1's Avatar
Just wanted to let you know that i sent you money for the tool package
Old Mar 27, 2006 | 12:36 PM
  #162
Zick's Avatar
Originally Posted by 2001 SOM WS6 69 GTO
Hi Zick,
Just wanted to double check with you, LS1 ??? Let me know
I don't quite understand what your asking?
I'll be using the tool to install Patriot dual springs onto a 317 6.0 head.
Old Mar 27, 2006 | 04:04 PM
  #163
2001 SOM WS6 69 GTO's Avatar
Zick, I sell two versions of the tool, a LT1 version, and then a LS1 version which covers LS2, LS6, LS7, 5.3 L truck, 6.0 L Truck. I just needed to know which style and now I know which you need. Thanks for letting me know and I will be mailing out your tool tomorrow morning.
ThirdGenLS1, I received your payment and also needed to know which style you needed but by looking at your Signature, it appears you also need the LS1. If you can let me know by PM to double check that would be great as I would like to ship your order in the morning as well. Thanks
Tim
Old Mar 27, 2006 | 06:02 PM
  #164
Zick's Avatar
Tim
Ah gotcha, thanks.
Old Apr 1, 2006 | 11:40 AM
  #165
Extinct SS's Avatar
Payment sent
Old Apr 1, 2006 | 01:05 PM
  #166
got my tool today....Thanks
Justin
Old Apr 6, 2006 | 12:37 AM
  #167
vader99's Avatar
Is this tool still available? I would like to buy the spring tool for the ls1.
Old Apr 6, 2006 | 01:27 AM
  #168
I'm sure it would be, i ordered mine last week
Old Apr 6, 2006 | 02:13 AM
  #169
vader99's Avatar
I just sent $35.00 USD by paypal for the ls1 spring compressing tool. I added the extra $5.00 since I am up in Canada.
thanks
Old Apr 6, 2006 | 07:14 AM
  #170
Hi Vader99,
When I get home from work I will check on the payment but I am sure it is there. I will email you later. Thanks
Tim
Old Apr 6, 2006 | 10:37 AM
  #171
Mid-Life Speed's Avatar
Ordered the tool package this morning by paypal !
Been waiting to do my cam swap and am finally ready.
Thanks,
Steve
Old Apr 20, 2006 | 10:00 PM
  #172
If you order a tool in the last 2 days your tools were shipped this morning. If anyone needs a tool I have plenty in stock ready to ship. Thanks
Tim
Old Apr 20, 2006 | 10:17 PM
  #173
vader99's Avatar
Received my tool on Monday. Can't wait to use it. Thanks for the speedy shipment, especially up to Canada.
Old Apr 20, 2006 | 10:46 PM
  #174
Steve in Seattle's Avatar
Do you have a LT1 tool with air-fill package?
If so, how much? I'll paypal it over ASAP.
Old Apr 21, 2006 | 06:50 AM
  #175
Hi Steve,
Yes I have LT1 tools in stock and have plenty of the Cylinder Air Fill Tools in stock as well. The Package Price is $ 50 Shipped. Let me know if you have any other questions. I will send an email when I receive payment. Thanks
Tim
Old Apr 24, 2006 | 08:37 PM
  #176
Loadre's Avatar
One tip I found usefull. Tim's tool is outstanding for taking springs OFF but some of those with taller/stiffer springs have to fight with it to get the springs back on. I've found that using Tim's tool to take them off, then use a simple hand screw type to compress the spring before sticking it back on cuts time in half.
Eventually you get the hang of just compressing it enough to pop the locks in, and in a very little amount of loosening the spring will start to seat and the pressure drops off quickly. Works like a charm. I do recommend buying or fabbing one that you can use a 3/8 ratchet on the top of to make things go even quicker cause those manual compressors stab your hands.
Old Apr 24, 2006 | 09:19 PM
  #177
vader99's Avatar
So, are you saying that Tim's tool does not work well with installing 918 springs or do you mean with springs stiffer than 918's? If so, I haven't heard that yet.
Old Apr 24, 2006 | 10:18 PM
  #178
Loadre's Avatar
On my LT1 it works, but I found the more efficient way to be use the screw type. The LS1's 'might' be different but I'm not sure. Anyone that's installed springs knows what I'm talking about, you have to get it centered perfectly in relation to the valve stem, can barely get the tool past the rocker stud enough to engage threads etc etc, have to finaggle it around to get the locks to drop in. It's just a pain.
Tim knows about this downfall as we've talked about maybe a longer stud as a fix. Don't get me wrong though, I'm NOT bashing Tim at all. You have to have his tool to swap springs!
Old Apr 24, 2006 | 10:35 PM
  #179
Hi Everyone,
Loadre is refering to my LT1 design tool which is very different to my LS1 Tool.
With My LT1 tool you use your exsisting rocker stud along with my tool, and Loadre was very helpful with some ideas as how to make my tool work better which by the way Loadre I am taking your advise and going to include the stud that you recommended that will get an extra 1/4 length of threads to where you will not have a problem of using my tool with extra tall springs.
My LS1 version tool I supply a special made stud that you screw into your head once the rockers are removed and then the tool slides righ over that. There is tons of extra threads on the stud to use with the extra tall springs so what Loadre is talking about IS NOT an issue with my LS1 version tool.
So to answer your question Vander99, my tool works flawlessly with 918 springs on the LS1 application.
So again what Loadre is refering to is with my LT1 Version tool and NOT my LS1 Version Tool. As for my LT1 Version I will be including a Stud as well now that will make Extra Tall Springs NOT an issue when using my tool.
Thanks for everyone's input and hope this clears up the confusion
Tim
Old Apr 24, 2006 | 10:52 PM
  #180
vader99's Avatar
Thanks for clearing that up Tim.
