Anyone Here Work with Fiberglass?
I know how to make a mold around the parts I'm trying to enclose, but the temperatures involved have me scratching my head. I've fixed vettes and boats in the past, but none of that got very hot. These bulbs are going to get pretty damn hot inside and I'm wondering how the fiberglass would hold up.
Does freshly laid fiberglass need to be baked to get all the liquid (?) out? I've heard of fiberglass hoods needing to be baked before they are painted, but I'm not sure what the hell is going on here.
Any advice?
http://www.fiberglasswarehouse.com/vinylester_resin.asp
but an email to the supplier might net you some more info on it
Also, What are you going to use for a "clear" lens???
I also found this article on preburning the assembly:
Paint, sealants and glue that are going to be used inside a headlight assembly must be preburned before assembling. During preburning, the temperature must at least reach the maximum a headlight will see during a extremely hot summer day, with all lights on and cooking hot engine. A typical item that needs preburning is optical shields or shrouds. Use an oven and set it to ~280F (~150C), without exceeding maximum temperature according to the paint, the sealant or the glues. First heat oven to desired temperature, then turn overn off. Wait 2-3 minutes for the elements to turn from red hot to black. A typical preburn time is 20-30 minutes. Because oven is off, uou may have to do a second round by repeating the procedure. In general, this applies to all kinds of glue, paint and sealants. If this is not done properly, fumes will fog up lenses and reflectors. It is not recommended to have this happening to your headlights. The only liquid that will attack condensed fumes are 90% rubbing alchohol or paint thinner. Many surfaces cannot take such harsh fluid. Reflectors is the worst. It can be difficult or impossible. You may actually find that it also removes reflective material.
