What size puller for the crank pully?
You can rent these at most parts stores. I bought several cheapies at Harbor Freight.com but they suk. I ended up with a Sears (gulp!) unit for 80 bucks that works great.
You need an install rod with the same threads as the crank bolt to re-install the crank pulley, however. I think the thread is a 19M if I recall correctly.
