who has a powder coating system?
Anyway you can adjust most guns to spray very light or heavy. Grounding the part is important, you will need a good charge for the powder to cling. I think you will find it very easy! Blast your parts if you can in a blasting cabinet for best results. I would look for low temp curing powders if you are using an old oven. You can mix acetone with powder for liquid color match chip repairs. Lots of info can be found here if you surf the site. cya
http://www.powdercoatingonline.com
