Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Flywheel locking tool
Old Feb 28, 2006 | 04:16 PM
Joel_SS's Avatar
Default Flywheel locking tool
Where can I get one of these? I did a search but nothing really turned up. I do not really want to use the screwdriver method..
Old Feb 28, 2006 | 04:22 PM
Super Speed's Avatar
Try your local VatoZone or Napa they should have one and I think autozone will even rent them
Old Feb 28, 2006 | 05:41 PM
davered00ss's Avatar
Moderator
I made my own, but summit has one for $35.
Old Feb 28, 2006 | 05:47 PM
Ωmega's Avatar
^^^ I have one just like that made by another member on the boards here. it also has holes for an ASP pulley. The Summit one is good too!
Old Feb 28, 2006 | 10:07 PM
Joel_SS's Avatar
Thanks All!
Old Mar 1, 2006 | 11:29 AM
Joel_SS's Avatar
Anyone have a part number for the summit tool?
Old Mar 1, 2006 | 12:20 PM
Ωmega's Avatar
Sme-906008
Old Mar 1, 2006 | 02:27 PM
mondi2002's Avatar
Do you have to have one to R&R the pulley? Can't you just put it in gear
with the ebrake on?
Old Mar 1, 2006 | 02:38 PM
Ωmega's Avatar
with the ebrake on?
M6's you can put into 4th gear. Autos dont work that way.
the Ebrake has nothing to do with the engine, it pulls a cable that's connected directly to the rearend.
Old Mar 1, 2006 | 03:24 PM
mondi2002's Avatar
Thanks, I forgot about autos. Mine is in route I should see by Tuesday. (SLP 25%UD)
Never installed one before.
Figured the car in gear & ebrake on should not hurt it.
Old Mar 1, 2006 | 06:55 PM
Moderator
I needed it even for my M6.
Old Mar 1, 2006 | 10:16 PM
ace68's Avatar
Sme-906008
nice tool
Old Mar 2, 2006 | 06:55 AM
mondi2002's Avatar
davered00ss, Why did you still need it? Clutch slipping?
If it comes to that I will just use an impact to remove it.
Old Mar 2, 2006 | 05:36 PM
Moderator
Clutch should not be slipping, new Spec Stage 3F. I was in 1st gear, don't think 4th would have made any diference.
Old Mar 2, 2006 | 05:53 PM
Ωmega's Avatar
It make a ton of difference. In 4th gear, you're at a 1:1 ratio. The whole drivetrain spins together in fourth.
Old Mar 2, 2006 | 08:32 PM
Moderator
Didn't put much thought into it, just doing the cam and needed to hold it still.
