Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Oil Pan & Covers Alignment Tools
Old Sep 14, 2006 | 01:17 PM
Gold Phoenix's Avatar
Default Oil Pan & Covers Alignment Tools
Has anyone really used these when they build-up their motor in their own garage? I saw in the latest GMHTP that they talked about them. Does anyone know where to get some knock-offs or besides from the dealers?
Old Sep 15, 2006 | 11:00 AM
crazykid's Avatar
Restricted User
No knock-offs, you can purchase the the tools off ebay. I use them evry motor build we do here at our shop.
Old Sep 19, 2006 | 08:29 AM
AllThrottle4U's Avatar
Can anyone elaborate on these tools, or why they are needed?
Old Sep 19, 2006 | 03:51 PM
Roy V.'s Avatar
Mis-alignment can cause a cracked oil pan which is what happened to me and some other GTO owners. A thread exists on the LS1GTO board but I can't find it at the moment:
http://www.putfile.com/pic.php?img=3260451
Kent-Moore J-41480 - Front and rear cover alignment tool; at oil pan:
Our friend the J 41480 is now tightened to the engine block, leaving the tool-to-front-cover bolts loose at this time. Like when used on the rear cover, these bolts get 18 lb-ft of torque.
http://www.gmhightechperformance.com.../photo_41.html
Kent-Moore J-41476 - Front and rear cover alignment tool:
Unlike the seal in the rear cover, the crankshaft front oil seal is not actually contacting any crank surfaces at this point; instead, it will ride on the harmonic damper (to be installed later). Therefore, the seal isn't doing anything to help align the cover to the block. Enter the J 41476 Front and Rear Cover Alignment Tool (Crankshaft Seal Area), also made by SPX Kent-Moore. This is installed hand tight using an old crank bolt. Note the alignment tabs on the cover that the tool presses up against; this tool aligns the cover side-to-side.
http://www.gmhightechperformance.com.../photo_42.html
Old Sep 21, 2006 | 06:48 AM
redbandit98's Avatar
i never used them, not to say you shouldnt, but mine never leaked or cracked..just torqued them in sequence and with a wrench.
Old Sep 21, 2006 | 09:39 PM
garrettpen's Avatar
Why do they crack?
Old Sep 26, 2006 | 12:46 PM
garrettpen's Avatar
nobody knows?
Old Sep 26, 2006 | 05:40 PM
00454sscamaro's Avatar
i think witht he ls1 the oil pans a structural part of the engine, wich would mean it sees some stresses from the motor if its not lined up right i could see the pan beeing weaker in the wrong orientation..
