Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
bleeding cluch
Old Sep 21, 2006 | 12:37 PM
rudyzturbota's Avatar
Default bleeding cluch
how in he helll do you use this thing. it has a bottle with tubes, are you suppost to fell up the bottle then conect the line to the bleed valve an keeo the mater felled as well, or do u keep the bottle empty, an just keep the master full while u push on cluch padle, it only has direction on how to do the brake system
Old Sep 21, 2006 | 02:10 PM
NOBR8KSS's Avatar
It's actually a little complicated the first time around...try this link out, it helped me a lot the first time:
http://mywebpages.comcast.net/buschm...utchbleed.html
After the first time around and getting all of the air out of the system, it is easiest to simply bleed it manually by pumping the clutch, holding, cracking the bleeder valve, closing the valve, and then pulling the clutch pedal back up. Keep fluid in the reservior and continue the process until the fluid runs clear.
