Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Engine building tools
Old Sep 30, 2006 | 10:32 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Engine building tools
What brand should I go with. Need a mic, calipers, dial bore gauge, etc. Which tools should I get? Ring compressor brand? Tq angle gauge? All the normal stuff.
Old Sep 30, 2006 | 11:36 PM
Shamrock98TA's Avatar
As for the mics and calipers, I use and would recommend the digital Mitutoyo. Dead nuts and not too expensive. As for the others, never used them.
Old Oct 2, 2006 | 09:54 PM
1slow01Z71's Avatar
aww come on I know some people on here build their own engines
Old Oct 3, 2006 | 03:39 PM
pittstatejc's Avatar
For a ring compressor get the pliers type KD is a good brand. Stay away from the type where you put a 1/4 ratchet in it and turn a band to tighten the compressor. Dial indicator is a good idea. You should also get some plastigauge. I don't know about a torque angle gauge, never used one of those. You should also get a hole micrometer to measure your cylinder and bearing bores. Obviously a torque wrench is a must.
Old Oct 4, 2006 | 07:09 AM
Camaroholic's Avatar
Sorry for the spam... mine are still for sale.
https://ls1tech.com/forums/lsx-parts-sale/541259-engine-building-tools-micrometers-bore-gage-set.html
They worked very well. Enco had about the lowest prices around, and fast shipping, so you might poke around their web site for the Mitutoyo stuff.
Old Oct 4, 2006 | 10:01 PM
1slow01Z71's Avatar
I was looking at their calipers, mine are kinda mickey mouse POS's(aka harbour frieght). Ill keep it in mind.
Old Oct 16, 2006 | 10:34 AM
DRVETTE's Avatar
7 Second Club
I hate the all around fits all ring compressors, get the true 2 step cnc ring compressor that only fits a certain size bore. There about 20.00 a piece but they will never destroy a ring when installing pistons. Dont forget a good bolt stretch gauge too, there invaluable.
Old Oct 16, 2006 | 01:22 PM
marv's Avatar
1Slow, GMHTP mag has a great article going on (4 part series I believe) about building/assembly your first engine (theirs is a stroker in this case). In the first article, a month or two ago, they had a good section on tool selection that might help you out.
They outlined what all was needed, what the cost was, and where to get it.
You might want to see if you can find it on the web, or maybe order the back issue.
Hope this helps.
