Painting question
Painting question
I got a ram air hood for my 2000 TA so i got the stuff to paint it in my garage. I am fixing some damage to my nose, and pass side fender being that i'm gonna paint hood anyways. I didnt have enough room in my garage where i have plastic up to do all the panels at the same time. I repaired and blended in the fenders with the base color but didnt spray any clear yet. It's a dupont paint I got at the local auto paint store. My main question is it recommends to spray clear 30 minutes after last base (flash) coat. Do I have to scuff/sand up the base coat if I am going to spray the clear a few days later ? or can I just hit it with degreaser etc... ? and If I do have to wet sand it what grit should I sand with before spraying the clear ? 600 or 800 ?
Thanks
Ron H.
Thanks
Ron H.
What color? If it's a solid (red, white, etc), you should be fine with the scotchbrite scuff. If it's a metallic, hmm... I'd really try to shoot it within a day, without scuffing. Those metal bits can be a tad finicky. Though the window says "30 minutes later", that's the minimum, the max is about a day. If it's cold, you might could even stretch that out a little more.
Thanks
Ron H.
p.s. There is a very slight amount of metallic in it I think but not very noticeable.
