Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Question About Helicoil
Old Dec 11, 2006 | 09:40 AM
XpEdItIoUs's Avatar
Default Question About Helicoil
Would you guys recommend helicoil for a stripped thread for a m6 transmission crossmember? I was torquing the bolts that hold the transmission crossmember to the floorboard and I stripped the thread.
Old Dec 11, 2006 | 09:53 AM
Camaroholic's Avatar
If you can snip the tab off of the helicoil, it'd probably work fine.
Me, I'd probably just tap it bigger and use a slightly bigger bolt.
Old Dec 11, 2006 | 11:13 AM
2000LS1TA's Avatar
Old Dec 11, 2006 | 08:31 PM
XpEdItIoUs's Avatar
Ok I guess I will put a bigger bolt.
Old Dec 12, 2006 | 01:11 AM
2001CamaroGuy's Avatar
helicoils work really well and are very strong
Old Dec 12, 2006 | 07:01 PM
LS1_4seater's Avatar
Helicoils only work if the bolt is fully threaded with the helicoil. I would consider a slimsert or a keensert. They are both much stronger and more durable.
Old Dec 13, 2006 | 08:21 PM
XpEdItIoUs's Avatar
I used helicoil and it worked great.
Old Nov 8, 2007 | 01:13 PM
MrEddie's Avatar
What setting did you have on the torque wrench? The factory manual states 66 lb ft, and I was able to torque 3 bolts but the 4th just didn't feel right so I just let off vs. stripping it. Also, since the metal the bolt is threading into is not too deep, how did you know what length of helicoil to use? Thx!!!
Old Nov 24, 2007 | 07:26 PM
FlyRydes's Avatar
Default helicoil
Timeserts are much stronger than helicoil. they are solid instead of wire
Old Dec 14, 2007 | 07:23 PM
Pirate BlackJack Jay's Avatar
Hey you are lucky you didnt break the damn bolt like i did when i was tourqeing my rear crossmember on my camaro.... i looked at neutnmeters(whatever it is) and not footpounds... and broke it.... not fun when ur in auto class and have to bum a ride to go pick it up at the chevy dealer... you can sign up for Mitchell1 on demand and they give you all the specs... OnDemand5.com
Old Dec 16, 2008 | 04:02 PM
MrEddie's Avatar
I may be dropping my tranny in the near future and was wondering what torque setting snapped your trans support bolts (4 cross member bolts)? I torqued mine to 66 ft lbs (at least three of them). I used the factory manual and confirmed via this torque setting sheet - http://www.texasfbody.org/TorqueSpecs/ However, I think installuniversity states 43 ft lbs for the bolts - I just don't want to strip nor have them undertorqued. Thanks!
Old Dec 16, 2008 | 04:04 PM
XpEdItIoUs's Avatar
I think it gave up on 60 ftlbs.
Old Dec 16, 2008 | 04:24 PM
MrEddie's Avatar
Is your helicoil still holding up? Did you install a short helicoil since there's not much female thread? I'm just getting a plan in case of bolt failure - Thx!
Old Dec 16, 2008 | 05:31 PM
XpEdItIoUs's Avatar
Its holding fine even with the th400 trans that took place of my t56.
Old Dec 16, 2008 | 05:32 PM
XpEdItIoUs's Avatar
I don't exactly recall what size i used but i think it was a short coil.
Old Dec 17, 2008 | 09:28 PM
schino's Avatar
you should have no problems with helicoil. im an engineer at an aerospace manufacturer and every tapped hole besides pipe or port uses helicoils. we go through hundreds a day
Old Dec 18, 2008 | 05:46 PM
mebuildit's Avatar
I agree Timeserts are the best way to go for that type of problem.
I have used them many times with great luck.
