Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Mandrel Tube Bender??
Old Jan 30, 2007 | 03:48 PM
MetallicaMatt's Avatar
Originally Posted by Armageddon
http://www2.northerntool.com/product-1/628.htm
first link that came up on google...
Note: Will not bend conduit or exhaust.
i saw that in my catalog, got excited but then saw the note on the exhaust
Old Jan 30, 2007 | 06:11 PM
Armageddon's Avatar
...with cheese.
crap, I thought those did.
Old Jan 30, 2007 | 08:16 PM
Wnts2Go10O's Avatar
http://www.ercolina-usa.com/mandrel-bender.htm zingo..doubt ull put down the coin to get one though
Old Jan 30, 2007 | 08:38 PM
yeah prolly 40-50k
Old Jan 31, 2007 | 09:14 AM
CTSmechanic's Avatar
Originally Posted by MetallicaMatt
i went to their website, and their 180* hydraulic bender only does 2" OD....that doesn't work when i'm using 2.5" and 3"
unless i'm looking in the wrong place...whata you have and how much did it set ya back?
I had a brain fart on this deal.... those wont work for exhaust and not a mandrel bender but a damn good tubing bender for everything else...
Old Jan 31, 2007 | 03:02 PM
VinR1's Avatar
assuming you filled the pipe with sand, why wouldnt the Northern Tool model work?
Old Jan 31, 2007 | 03:39 PM
maybe it would work if the tube was filled with sand...hurm
Old Jan 31, 2007 | 04:08 PM
Armageddon's Avatar
...with cheese.
That's what I was thinking after you said no exhaust. That's the purpose the sand serves is to simulate a solid tube. Just make sure it's packed tight with no air pockets.
Old Jan 31, 2007 | 04:11 PM
that one from northern tool doesn't have any kind of angle markings on it.
I don't understand why i can't find the lever style hand bender, I haven't found one that goes above 2"....
this is getting to be a PITA
Old Jan 31, 2007 | 05:46 PM
mitchntx's Avatar
I bought the Model 3 tubing bender for $300 to fabricate roll cages.
www.jd2.com
It only goes up to 2" pipe. Might be worth a call to see if they have anything to accept tubing as large as exhaust tubing.
Old Feb 6, 2007 | 09:20 PM
jester1's Avatar
unfortunatly they dont,
good decent bender my neighbour just bought one, make sure the dies are good though. If the pipe is thin walled it does kink the first portion where its clamped but it might be the die it self doing that.
Old Feb 6, 2007 | 09:41 PM
  #32
NWDragRacer's Avatar
That's a PIPE bender - much different than a TUBING bender.
Pipe is measured ID and tubing is measured OD.
Old Mar 26, 2007 | 06:09 PM
  #33
ROCNDAV's Avatar
Matt, did you ever get any more info?
I was looking at this guy
http://www.harborfreight.com/cpi/cta...emnumber=35336 ($199), but I occasionally get 15% coupons via email.
You can download the manual from their site: http://www.harborfreight.com/manuals...5999/35336.PDF
Page 4 of the manual reads:
The pipe bender is designed to bend water pipe and heavy gauge galvanized pipe that is used in commercial applications. When bending thin-walled pipe eg conduit etc, you may have problems with the pipe becoming kinked or creased. To limit the amount of creasing, fill the pipe with sand and cap teh ends before bending.
[img]file:///C:/DOCUME%7E1/dmcafee/LOCALS%7E1/Temp/moz-screenshot.jpg[/img]
I remember seeing mandrel ***** on ebay before as well. You can put some of them in the pipe before a bend as well as the sand.
Old Mar 27, 2007 | 04:04 PM
  #34
i don't really want to have to fill everything with sand
i guess i'm just going to bite the bullet and fab up what i have and go to stainless works
Old Mar 29, 2007 | 02:06 PM
  #35
badtexasZ28's Avatar
www.tubeshark.com
Old Mar 29, 2007 | 02:29 PM
  #36
ROCNDAV's Avatar
Originally Posted by badtexasZ28
Looks good, but it looks like it only goes up to 2". THere is an option for a 3" die, but I don't see anything else about it.
Old Mar 29, 2007 | 04:52 PM
  #37
I contacted them a couple weeks ago
only goes to 2", and the 3" wont be out for another year
Old Mar 29, 2007 | 05:01 PM
  #38
ROCNDAV's Avatar
at my rate, I might still be buildig my car, so it might work for me.
Old Apr 4, 2007 | 02:56 PM
  #39
RiceKilla's Avatar
Make sure before you pack the sand in the tube, to bake it and get rid of all the moisture. I wouldn't want to be there if you have to heat the pipe to bend it, and there's moisture, POP!
Also, Jeg's sells them for pretty cheap and they get to your house in 2 days.
Old Apr 4, 2007 | 03:45 PM
  #40
ROCNDAV's Avatar
Jegs sell the benders? or the pre bent pieces?
How the heck would you cap a pipe and fill it? plumbing rubber cap? or actually weld it closed? thats a lot of work for each bend.
